Questions on Brenspeed's Stage 1&2 brake kits
Old Nov 17, 2006 | 12:20 PM
Louie's Avatar
Has anyone installed the Stage 2 brake kit from Brenspeed? If yes, how big is the improvement?
Also, would the Stage 1 kit (Hawk HPS pads + steel brake lines) already provide significant improvement, considering it's meant for the stock rotors?
Here's Brenspeed's ad for the Stage 2 kit:
Old Nov 17, 2006 | 12:44 PM
05BlackGT's Avatar
I have the stage 2 package and highly recommend it. It's an excellent kit for the price. You'll spend 3-4X the money to get anything better.Although the Motul fluid is a very good track fluid, it is very hydroscopic, so I opted for ATE fluid instead.
Old Nov 17, 2006 | 02:10 PM
tom281's Avatar
What the heck does hydroscopic mean?
Also, what are the pros/cons of drilled rotors versus slotted?
Old Nov 17, 2006 | 02:22 PM
WERKED 66's Avatar
as far as i have heard drill rotors are not good to use cause they can crack where they are drill.....someone correct me if i am wrong.......
Old Nov 17, 2006 | 02:28 PM
Louie's Avatar
I'm sure he meant hygroscopic, meaning it has a tendency to incorporate and retain water.
That's why I'd go for the slotted rotors.
Old Nov 17, 2006 | 03:44 PM
blkstang06's Avatar
From
personal experience I know of no cons for either style of rotor!.. I do think with drilled you tend to get best of both design functions, matter and heat dispersement!
Old Nov 18, 2006 | 04:14 AM
sodaman's Avatar
depends on how they are drilled wether they are proned to cracking. I have had both styles and I prefer the drilled models myself. I dont have them on the mustang yet, but I have been looking at rotorpros.xxx
and I also recieved a pm and was told where to get those same rotorpros for a bunch cheaper as well. If you are interested in some drilled and possibly colored rotors contact rotorpros. good luck
Old Nov 18, 2006 | 04:48 AM
fastduo's Avatar
Drilled rotors are fine for the street but you do not want them for the track (road coarse) and the constant expansion and contraction may cause cracking between the drilled out sections due to the heat. Slotted is a better way to go.
Old Nov 18, 2006 | 04:53 AM
tx2005gt's Avatar
i have been looking at the rotopros, hawk hps pads & the earls hose kit. you can get into this set-up for a whole lot less.
Old Nov 18, 2006 | 02:41 PM
scramblr's Avatar
Do you have some links for this set up?
Old Nov 18, 2006 | 04:09 PM
GRAYPNY's Avatar
I just ordered this setup and although people say that drilled rotors aren't good for the track because of cracking Rotorpros will replace them if they do. I do a little track time in the summer and I'm probably not capable of driving hard enough to crack the rotors. JMO~
PM sent Alex
Old Nov 18, 2006 | 04:14 PM
tx2005gt's Avatar
try these
http://www.inmotionperf.com/cart/ind...ewCat&catId=87http://www.scm-performance.com/
Old Nov 18, 2006 | 10:11 PM
GRAYPNY's Avatar
The Earl's brake lines are very nice and that is a good price.
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
Jim74656
May 1, 2023 02:15 AM
SickShade14
Aug 29, 2015 04:18 PM
DarrenGT
Aug 21, 2015 07:07 PM
AMWill
Jul 20, 2015 08:40 AM
