question for all who have taken off front tires...
Old Oct 22, 2005 | 06:32 PM
DraftHorsePower's Avatar
i have a weird bump noise in my right front wheel/suspension (no it's not the TSB issue) and since all the Ford service tech's are too pig headed to look past the fact that the car is lowered and figure out what is going on... i am trying to figure it out myself.
Now, all of the bolts EVERYWHERE are tight (the most recent excuse of techs were that the bolts were loose) i am tempted to replace the strut myself because i think that might be it....
BUT on examination of the car today with that wheel off to check the bolts, we noticed that the wheel bolts that stick out of the brake assembly have a lot of "play" in them, enough to make a giant "CLUNK" noise when moved back and forth in the assembly. I think with a tire on this could be the noise, since it would be more muffled.
So... are those wheel bolts supposed to move back and forth so much?
Old Oct 22, 2005 | 07:37 PM
Import-Slaya's Avatar
No way should there be that much play in the wheel studs. I've had my front wheels off and they are rock solid (as they are in every other car I've worked on--Mustangs or not).
I'd get this checked ASAP by another dealer who realizes that this isn't related to the lowering springs.
Old Oct 22, 2005 | 07:55 PM
f1-cobra's Avatar
Mine were solid until I removed the factory retaining clips to put on the aftermarket rims. Now the rotor is loose but there is no noise coming from the wheels.
Old Oct 22, 2005 | 09:45 PM
pittperson's Avatar
Doesnt the fact that the rotor is loose raise a red flag?
Old Oct 22, 2005 | 11:05 PM
Stoenr's Avatar
The rotor should be loose with retaining clip off, and no lug on the hub. Stil need to remove Caliper to remove rotor, but you get the idea.
Old Oct 23, 2005 | 11:11 AM
f1-cobra's Avatar
The clips were used by AAI to hold on the rotors as the car went down the line. They should always be removed when putting on aftermarket rims in order for them to fit.
Old Oct 23, 2005 | 01:29 PM
hmmm yea well i do have aftermarket wheels, but that noise started when i drove the car off the lot so that wouldn't be it. I still think they are pretty loose though? Do you think it would be able to make a clunk noise going over bumps if the wheels are moving? i think it may be jarring it enough.
The studs probably move back and forth a good 1/2 inch.
Old Oct 23, 2005 | 01:58 PM
dustindu4's Avatar
9 is not my lucky number.
My studs are never loose. Just for you Em I'll go take my tire off and double check.
Old Oct 23, 2005 | 06:24 PM
dustindu4's Avatar
Check this out. There's rotational slop but the studs are rock solid. I haven't done anything to my brakes.
http://home.comcast.net/~dustindu4/steeda_...install_025.wmv
So I think this is what you are describing.
Old May 24, 2006 | 09:56 PM
John SCB's Avatar
Just to bring this thread back into the light...
The above video shows EXACTLY what i'm seeing in my front hubs.
Soooo, is this NORMAL?
Looks kinda dangerous to me....
Old May 24, 2006 | 10:06 PM
don_w's Avatar
Dangerous how? Once the lug nuts are torqued down, it's not moving anywhere.
Old May 25, 2006 | 05:29 AM
RPM's Avatar
RPM
Whatever you noise is it sure aint the wheel studs causin' it.
Old May 25, 2006 | 06:13 PM
traffic142's Avatar
Does anyone have any pics of these clips??
Old May 25, 2006 | 06:22 PM
don_w's Avatar
No photos, but this shows them...
http://www.2005stang.com/gallery/alb...ake%20Disc.pdf
Old May 25, 2006 | 07:47 PM
SixtySix's Avatar
Completely normal. Like Don said once the lugnuts are on, it ain't going anywhere.
Those retaining nuts are just "placeholders" as are the clips on the front calipers.
Both should be removed if you're going to aftermarket rims.
Old May 25, 2006 | 10:02 PM
300HPGT's Avatar
Well I did have a weird bump noise after I lowered my car but My sway bar end links were loose and they looked tight. Be sure to check everything.
Old May 26, 2006 | 04:21 PM
scramblr's Avatar
Hey DraftHorse,
Check this thread out if you haven't already....
http://forums.bradbarnett.net/showthread.php?t=44888
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
