Question about Rear Swaybars
I'm considering the purchase of a new swaybar but have a few questions.
From what I've seen all aftermarket rear swaybar are the same diameter as the stock rear sway. So with that said what's improvement to be had if they only difference is the bushings? Why not just switch those out and keep the stock bar? Someone that know's what they're talking about please explain. Thanks.
1 Post
http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
This one is interesting, except for the price tag. Never seen an adjustable rear anti-roll bar before.
http://www.hotchkis.net/p-617-05-mus...sway-bars.aspx
Ours are solid - .875" material - and adjustable. Heres some info (front and rear):
Stillen Adjustable Rear (.875” Solid) – 3 Way Adjustable
Hole #1
180 LBS @ 1” Travel
28.6% Stiffer
180 LBS @ 1” Travel
28.6% Stiffer
320 LBS @ 2” Travel
39.1% Stiffer
39.1% Stiffer
Hole #2
200 LBS @ 1” Travel
42.9% Stiffer
200 LBS @ 1” Travel
42.9% Stiffer
390 LBS @ 2” Travel
69.6% Stiffer
69.6% Stiffer
Hole #3
230 LBS @ 1” Travel
64.3% Stiffer
230 LBS @ 1” Travel
64.3% Stiffer
450 LBS @ 2” Travel
95.7% Stiffer
95.7% Stiffer
Stillen Non-Adjustable Rear Bar
200 LBS @ 1” Travel
42.9% Stiffer
42.9% Stiffer
350 LBS @ 2” travel
52.2% Stiffer
52.2% Stiffer
Stillen Adjustable Front (1.375” OD x .250 DOM) – 4 Way Adjustable
Hole #1
465 LBS @ 1” Travel
5.7% Stiffer
465 LBS @ 1” Travel
5.7% Stiffer
1000 LBS @ 2” Travel
0% Stiffer
0% Stiffer
Hole #2
530 LBS @ 1” Travel
20.5% Stiffer
530 LBS @ 1” Travel
20.5% Stiffer
1165 LBS @ 2” Travel
16.5% Stiffer
16.5% Stiffer
Hole #3
570 LBS @ 1” Travel
29.5% Stiffer
570 LBS @ 1” Travel
29.5% Stiffer
1210 LBS @ 2” Travel
21.0 % Stiffer
21.0 % Stiffer
Hole #4
610 LBS @ 1” Travel
38.6% Stiffer
610 LBS @ 1” Travel
38.6% Stiffer
1410 LBS @ 2” Travel
41.0% Stiffer
41.0% Stiffer
Please give me a call (866-278-8287 x134) if there is anything I can do to help.
Page
9/1/15 01:19 PM
