Pypes Violators 304 vs. 409 Stainless steel...is the extra cost worth it?
Old Sep 12, 2008 | 12:27 PM
Rebel73's Avatar
Looking at a set of Pypes Violators, and the price of the 409 set at $189 is pretty attractive. But what is the potential downside of going with the 409 vs. the 304? Is it more prone to rusting? If so, can this be controlled somehow?
Old Sep 12, 2008 | 12:46 PM
PIKE2244's Avatar
Just to be on the safe side I would go with the 409, especially if you live near the ocean... If you go w/ 304 it won't more than likely rust but if you can afford the 409 I would do it...
Old Sep 12, 2008 | 02:55 PM
metroplex's Avatar
T304SS is actually more corrosion resistant than T409SS, but T409SS is less expensive and a stronger alloy due to more iron and titanium content.
Old Sep 12, 2008 | 03:01 PM
70MACH1OWNER's Avatar
You need to look up the difference between the 2 types. I agree with everything you say but you need to swap the 304 and 409 part. 304 will NOT rust. 409 is magnetic, cheaper and will rust in time. 409 is magnetic because it has iron in it . So in short REBEL spend the few extra bucks and go with the 304 SS muffs.
Old Sep 12, 2008 | 03:50 PM
PIKE2244's Avatar
Yeah I realized that after I wrote it but I was in a rush to leave the hospital and didn't feel like fixing it right then and there. If somebody didn't respond by the time I got home I was going to fix it...
Old Sep 12, 2008 | 04:09 PM
Rebel73's Avatar
Hmmm...response from Brenspeed about this subject:
Q: What is the benefit of the 304 Steel vs. the 409 on the Pypes Violator
mufflers? Is it mostly looks or is the 304 more rust resistant? thank you
A: Either one will resist rust but you will get more of the minor surface rust
with the 409. basically just for cosmetics.
Old Sep 12, 2008 | 04:17 PM
Well I have to agree with their statement. 409 SS is what most factory exhausts are made from today. 409 SS will resist rust many time better than the old aluminized steel exhaust that rusted out in 2-3 years. 409 will last about 7 years as a daily driver here in Ohio. 304 SS will last many time longer. Borla's are made from 304 SS and that is why they give a million mile warranty on their mufflers.
Old Sep 12, 2008 | 04:28 PM
Rebel73's Avatar
Yah, I do notice that Brenspeed has a lifetime warranty on the 304 and not the 409...
Old Sep 12, 2008 | 10:00 PM
m05fastbackGT's Avatar
If you plan on keeping your ride for more than 5 years, I would definitely invest the extra $$$ for the 304 grade SS !
Old Sep 13, 2008 | 07:34 AM
metroplex's Avatar
409SS is stronger than 304SS due to more iron content and titanium content. OEMs pick 409SS because of its durability and lower cost. Rust can be sanded away on 409SS and repainted as long as you don't need to see something shiny. 7-10 years sounds about right for the rust belt.
Old Sep 13, 2008 | 08:55 PM
highvolts's Avatar
However, with all these responses telling you to go with the more expensive set, if you are looking just to try something different, go with the cheaper one!
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
GLOCKer
Sep 28, 2015 05:20 PM
Sep 24, 2015 08:15 PM
