PowerHouse Shaft Pics.
This is very nice.Have not taken the OEM one out yet to compare but,It is very light.
the stock piece is heavy as $hit you will see,that is a nice piece,hope to get 1 soon.
Location: New Carlisle, Ohio (20 miles north of Dayton)
Hey Mike,
Where can I get one and how much. Others are as much a $750 - $1000 bucks. Not worth that , but I would spend say $400.
Scott
![Wub](https://themustangsource.com/forums/images/smilies/wub.gif)
Hey Mike,
Scott![Wub](https://themustangsource.com/forums/images/smilies/wub.gif)
Scott
Just bought one of thos aluminum shafts. I can't wait til the car is back and i can bolt it in. I did not want to change pinion flanges and all that involved in Ranger shaft conversion. This shaft bolts right in from the box.
I took out the stock shaft to put in the new clutch and the thing weighs nearly 65 lbs. I could barely get it out of the car. Also to let you guys know the bolts on the rear end side are tough to get out with a ratchet alone. use something that will spin them out once you break them loose.
WOW after looking at those pictures, I can say that it is EXACTLY the same as the ones out of the ford rangers, it just has a sticker on it.
let us know how it feels in the car!!
I highly doubt it was just shortened. I have spoken with the guys at Powerhouse quite a few times. And from what I was told it will hold a 1000 horsepower. I don't think a ranger factory shaft would have that kind of strength?
mike how's it feel?
The shaft itself might be but i am sure the ranger doesnt come with heavyduty Spicer Joints and Spicer adapters.I did notice there sticker is right over a part number thou.
trust me, it is the same exact shaft just shortened a bit.
mike how's it feel?
mike how's it feel?
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
tee hee hee![Bat](https://themustangsource.com/forums/images/smilies/bat.gif)
Originally Posted by cmm101
Is this powerhouse shaft a direct bolt in for the automatic gts or only the manuels
That thing does look good. It should solve one of the "clunks" in the car, too, right? I remember someone saying there are some sort of bushing in the stock two-piece that make some of the noise...
Mike E
Mike E
