PowerHouse Shaft Pics.
Old May 24, 2006 | 04:45 PM
mikem's Avatar
This is very nice.Have not taken the OEM one out yet to compare but,It is very light.
Old May 24, 2006 | 04:52 PM
jp's performance's Avatar
the stock piece is heavy as $hit you will see,that is a nice piece,hope to get 1 soon.
Old May 24, 2006 | 05:50 PM
70MACH1OWNER's Avatar
Hey Mike,
Where can I get one and how much. Others are as much a $750 - $1000 bucks. Not worth that , but I would spend say $400.
Scott
Old May 24, 2006 | 06:25 PM
don_w's Avatar
Hey Mike,
Scott
The Powerhouse unit is $700... I bought mine here: http://powerhouse411.com/catalog/ind...products_id=27
Old May 25, 2006 | 02:11 PM
uberPony's Avatar
Just bought one of thos aluminum shafts. I can't wait til the car is back and i can bolt it in. I did not want to change pinion flanges and all that involved in Ranger shaft conversion. This shaft bolts right in from the box.
Old May 25, 2006 | 09:57 PM
300HPGT's Avatar
I took out the stock shaft to put in the new clutch and the thing weighs nearly 65 lbs. I could barely get it out of the car. Also to let you guys know the bolts on the rear end side are tough to get out with a ratchet alone. use something that will spin them out once you break them loose.
Old May 25, 2006 | 10:40 PM
Mongoose's Avatar
How about a air ratchet?
Old May 25, 2006 | 10:45 PM
300HPGT's Avatar
yeah buddy!!!! that is what I used. Need about 120 PSI in the tank tho.
Old May 26, 2006 | 08:06 AM
atomic_il's Avatar
WOW after looking at those pictures, I can say that it is EXACTLY the same as the ones out of the ford rangers, it just has a sticker on it.
let us know how it feels in the car!!
Old May 26, 2006 | 03:54 PM
mikem's Avatar
Looks like it,But it has been shortened.
Old May 26, 2006 | 06:45 PM
redroc's Avatar
I highly doubt it was just shortened. I have spoken with the guys at Powerhouse quite a few times. And from what I was told it will hold a 1000 horsepower. I don't think a ranger factory shaft would have that kind of strength?
Old May 27, 2006 | 07:52 PM
atomic_il's Avatar
trust me, it is the same exact shaft just shortened a bit.
mike how's it feel?
Old May 27, 2006 | 08:20 PM
mikem's Avatar
The shaft itself might be but i am sure the ranger doesnt come with heavyduty Spicer Joints and Spicer adapters.I did notice there sticker is right over a part number thou.
Old May 27, 2006 | 08:24 PM
mikem's Avatar
mike how's it feel?
It Feels Real Good.Would you like to Touch it:gay:
Old May 28, 2006 | 05:11 PM
atomic_il's Avatar
tee hee hee
Old May 28, 2006 | 05:16 PM
Kluski's Avatar
I am not sure, but did I hear that Ford will make a lighter shaft for the Mustang?
Old May 28, 2006 | 07:50 PM
cmm101's Avatar
Is this powerhouse shaft a direct bolt in for the automatic gts or only the manuels
Old May 29, 2006 | 07:07 AM
mikem's Avatar
tee hee hee
Sorry ,Just had to do it..............
Old May 29, 2006 | 07:26 AM
fin1's Avatar
It's for both
Old May 29, 2006 | 03:12 PM
mikeelia's Avatar
That thing does look good. It should solve one of the "clunks" in the car, too, right? I remember someone saying there are some sort of bushing in the stock two-piece that make some of the noise...
Mike E
