power shifting
Old May 27, 2005 | 11:25 AM
frank's Avatar
I'm new on a manual trans and I want to know if it's the only way (power shifting) to make the 0-60 in 5 sec and I want to know if it's very hard on transmission..tanks in advance
Old May 27, 2005 | 11:33 AM
KansasCityTim's Avatar
My dad used to power shift in his 442 all the time when he drag raced. Of course, he went through 3 transmissions to learn how, if that tells you anything.
Old May 27, 2005 | 11:41 AM
scottie1113's Avatar
Yes, it's hard on the tranny. I wouldn't want to have to spend the money to replace one just to shave a couple of tenths of the 0-60 time. I think the car is already fast enough, but it's your decision. If you continue to do this, be prepared to write a big check.
Old May 27, 2005 | 11:45 AM
Rebel73's Avatar
Silly question, but what exactly IS power shifting?
~Rob
Old May 27, 2005 | 11:48 AM
~Rob
Shifting with no clutch. At certain RPMs, the tranny and engine sync up so that using the clutch is "optional". Of course in the process of finding those points, you can really hurt the transmission, and even then, you have to be precise to hit it at the right time.
Old May 27, 2005 | 11:52 AM
SurfnSoCal's Avatar
I thought power shifting was keeping your foot on the gas even while shifting with the clutch. You push the push in half way, and slam the gears in and out...all while giving it lots o gas.
Old May 27, 2005 | 11:55 AM
mmoonshot's Avatar
You will damage youre tranny if you powershift regularly with the stock shifter, IMO, dont do it....
Old May 27, 2005 | 12:10 PM
tw0scoops123's Avatar
Originally posted by KansasCityTim+May 27, 2005, 12:51 PM--><div class='quotetop'>QUOTE(KansasCityTim @ May 27, 2005, 12:51 PM)</div><div class='quotemain'>Shifting with no clutch. At certain RPMs, the tranny and engine sync up so that using the clutch is "optional". Of course in the process of finding those points, you can really hurt the transmission, and even then, you have to be precise to hit it at the right time.
[/b]
<!--QuoteBegin-SurfnSoCal
@May 27, 2005, 12:55 PM
[/quote]
I think that name Power Shifting is used for both methods. Yes it's hard on the tranny. Also, I'm not sure if you can do the power shifting as in reaching the prime RPM where the gear is synched up with the collar. Modern cars now have synchronizers which allow the collar and the gear to make frictional contact before the dog teeth make contact. Eliminates the need for double clutching too.
Old May 27, 2005 | 12:22 PM
hbmach's Avatar
Back in the day, "power shifting" was shifting without using the clutch. "Speed shifting" was using the clutch and leavig gas pedal at full throttle. I wouldn't recommend power shifting unless you are racing for large sums of money.
Old May 27, 2005 | 01:17 PM
Rebel73's Avatar
oh heck NO, I'd never do that to my tranny, unless I raced for a living.
~Rob
Old May 27, 2005 | 01:33 PM
Shea's Avatar
There is no point in shifting without the clutch. It won't save you any time.
Powershifting is keeping your foot in the gas while you clutch and shift. That will save you time, and although it is a little hard on the trans., I do it and I've never had a trans. go on me after owning 6 Mustangs with the T-5.
Old May 27, 2005 | 01:35 PM
I think there are a great number of hot rodders from the 60s and 70s that would disgree with you, both about the definition and need for powerpooing.
Edit: HA HA.....I guess I forgot the "f" in "shift", and this is the result. How many other people here have ever powerpooed?
Old May 27, 2005 | 02:03 PM
bigaloz's Avatar
I used to powershift my 12 second 1991 LX all the time, tranny still in the car with no problems
Old May 29, 2005 | 09:59 PM
2K3 Mach's Avatar
Get a shifter with stop points. Pulling the shifter hard into the gear will gradually bend your input shaft (I think... it bends something in there)
Getting a shifter with stop points will prevent you from bending it when you powershift.
Old May 29, 2005 | 10:03 PM
Captmojo's Avatar
I learned to do it in High School, street racing. It took 2 trannys to learn, but it was great afterwards. But now I'm older and hopefully wiser. It not worth the frustration and fear factor trying to slam the shifter at the right moment and very clearly hearing the grind when you miss.
Don't do it, just enjoy the ride.
Old May 29, 2005 | 11:13 PM
Fordracing200's Avatar
[/b]
no, it is not shifting without a clutch :nono:
[/quote]
pretty much what he said
Old May 29, 2005 | 11:14 PM
Get a pro 5.0 shifter, and learn how to do it on a dealer car, take one for a 'test drive' and learn that way.
Old May 29, 2005 | 11:17 PM
ha ha, u dont know what u r talking about, the one u qouted does, so learna nd research before u post, that way u dont look like a idiot.
Old May 29, 2005 | 11:20 PM
Dan's Avatar
Dan
Do You Remember Me?
I don't do it and I'd advise most not to unless your a hard core dragger with money to spare.
Old May 29, 2005 | 11:32 PM
wild stray's Avatar
