posi rear end an option??
went to the ford web sight and built an 07 gt to see what the changes are for the new model year and a posi was a $100 option??????????
buyer beware if your grabbing a car off a dealers lot, be sure it has a posi!!
jay
jay
So what does it have stock? Is it a 3.27 non-limited slip. I would actually like the taller ratio for better mileage reasons but would not want to give up the limited slip. What do the aftermarket limited slip differentials cost? 600-700 dollars? Would it cost alot to get it installed?
Choose what ratio you want.
First of all, "posi" is a General Motors term
Second, all GT's still come with t-lock rear ends. The option you saw has nothing to do with it being an open rearend, it's strictly for the gearing. For 2007, all GTs come with a 3.31 ratio. The 3.55 ratio is now an option on manual tranny GTs. The only difference here is in 05 and 06 the 3.55 ratio was standard on manual tranny GTs.
Second, all GT's still come with t-lock rear ends. The option you saw has nothing to do with it being an open rearend, it's strictly for the gearing. For 2007, all GTs come with a 3.31 ratio. The 3.55 ratio is now an option on manual tranny GTs. The only difference here is in 05 and 06 the 3.55 ratio was standard on manual tranny GTs.Does anyone know what kind of benefit one might stand to gain. Obviously MPG will improve, but by how much?
