Please help. Need to identify broken part for Vortech install
Hey guys,
Thanks in advance for helping me identify this part. I bought a Vortech S/C H.O. with cooler(4FU218-028SQ). It came off a show car with 3 hours use on it.
The parts arrived and while checking them over I found this. I called my Ford salesman but he is off today and Vortech is already closed. Hopefully I can identify this so I know what to ask for and can hopefully be able to proceed with my install this Saturday as planned.
Around the lip it says 190904 but then the rest of the lip is broken so I don't know if the # continues. I cross referened that # against the parts list from Vortech but no luck finding a match.
![](http://i78.photobucket.com/albums/j112/majeanette/BrokenVortechpart002.jpg)
![](http://i78.photobucket.com/albums/j112/majeanette/BrokenVortechpart006.jpg)
![](http://i78.photobucket.com/albums/j112/majeanette/BrokenVortechpart007.jpg)
Again, Thanks!
Again, Thanks!
Originally Posted by korinwoodo
Thats the plug that keeps the uviverse vacuuming itself into a spinning vortex of mangled and twisted matter, please put it back.
Originally Posted by blackhat
It's mine I tell ya. MINE. ALL MINE! *evil laugh*
OK, I think I have it figured out. It is ...... *drum roll* the water pump inlet!! ...
*taps mic* Is this thing on?![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
There is a pic of it (I think) on page 28 of the Vortech instructions, figure 8B-d. I only have the free PDF reader so I can't make a pic of it.
Here's a pic of the part I have. Basically, it looks like they completed the step and this water inlet is inside one of the tubes already attached on my part.
I was going to remove the tube and check but I'm not familiar with the type of clamp being used and didn't want to open it not knowing if it can be re-used or not. I think it is in there though since the hose is left attached to the oil cooler from their working operation of it.
Here's the pic:
Here's the pic:
![](http://i78.photobucket.com/albums/j112/majeanette/BrokenVortechpart016.jpg)
I'm not sure because it is hard to judge the size of it based on the pictures, but it looks like the vacuum fitting that goes into the brake booster. The fittings that Ford uses on these cars fit in very tight, and are very easy to break if you try to remove it, which is what I am guessing happened.
Thats my phycatrist, as I clearly stated. I think you are a dunce.
http://forums.bradbarnett.net/showthread.php?t=49005
We need a new C/T for you.
![Stick Out Tongue](https://themustangsource.com/forums/images/smilies/tongue.gif)
Originally Posted by 1969 Mustang Mach 1
hey. Do you know everything? I don't think so.
Oh boy, me and you in another argument
Moving on, I didn't say I know everything, I just said that your bad at the English comprehension thing.
Here's the pic from the instructions. I saved it into a Word doc.
i notice your avatar that both of us are similar. We like to argue. and im a high school student too. going to 10th grade.
Going back to topic, you should really ask the guy you bought the supercharger to see what happened
It's an inch and a half long and an inch and 1/4 in width. Yeah, looking closely I can see three scrape marks on each side where they must've tried twisting it with a tool.
cant see the pic
I just tried the link and it worked. Click on it, and choose "open" and it will bring you to the page I saved. If that still doesn't work let me know and I'll try something else.
