Pinion Flange Nut?
Old 12/9/07 | 07:56 PM
'90 SSC Clone's Avatar
Pinion Flange Nut?
Could someone tell me what size the pinion flange nut is? I would like to make sure I have the correct size tools before I start my project. I believe it is a 22mm on my Foxbody but haven't crawled under this one yet to check.
Also will be changing out the pinion flange along with the driveshaft, would anyone happen to know what the torque is on the pinion nut?
Old 12/9/07 | 09:12 PM
Anyone?
Old 12/9/07 | 11:29 PM
2MFF's Avatar
27mm
This thread should have all the info you need
http://www.s197forum.com/forum/showthread.php?t=1104
Old 12/10/07 | 01:15 AM
70MACH1OWNER's Avatar
Hey Bobby,
I am in the process of trying to pull my pinion flange today. The nut is in fact 27mm. It just happens to be exactly 1 1/16. I am using an 1 1/16 six point socket and it fits great. The pinion nut torques to 120-150 ft/lbs. However, getting the nut off is proving to be a female dog. I used a air impact and breaker bar today and no luck. I will be cutting a cheater bar at work today plus I am soaking it in PB Blaster. I also think that nut has loctite on it from the factory. Good luck on yours!
Scott
Old 12/10/07 | 01:45 AM
Thanks guys, but is Ford using different size pinion nuts on these cars?
27mm or 22mm?
Old 12/10/07 | 01:50 AM
27mm or 22mm?
Bobby,
I edited my post above. It really is 27mm and you can use the 1 1/16th socket.
Scott
Jim74656
5/1/23 02:15 AM
Linkspure
9/12/15 06:33 PM
DoubleBlown
9/8/15 06:33 PM
rusilsalgado
1994-2004 V-8
7/27/15 09:13 AM
Quick Reply: Pinion Flange Nut?
