Pinging question
Old Apr 16, 2008 | 08:33 PM
brown spit8's Avatar
Pinging question
A little while back i noticed a noise coming from the floorboard area that i couldnt pinpoint. anyways i posted on the forum about it and did the recommended things like put washers where the bell housing bolts were.
Anyways, i dont think it could be pinging because it continues after i shut off the engine. Someone suggested the gauges sometimes make noises ticking in these cars. Im thinking about calling Steeda and to what they say.
Old Apr 16, 2008 | 08:50 PM
shaun_beauchamp's Avatar
How long you had the long tubes? Are you describing the exhaust ping from heating / cooling. This is normal for new exhaust as the metal needs to go through a few heat cycles. Once that is over, they will still do it if you beat them hard enough to generate a lot of heat. If you beat a Explorer or anything it will ping a bit once you shut it off.
Old Apr 16, 2008 | 08:58 PM
Nah i have had the long tubes for about 2 years now, the noise started after i beat the hell out of it one day after i got the 4.10s a couple months back
Old Apr 16, 2008 | 09:02 PM
No one really heres it but me, everyone i point it out to swears im crazy
Old Apr 16, 2008 | 09:04 PM
Those are guilt noises. Wash the car, fill the tires to the correct psi, put some good fuel in it and drop a coat of wax on it. You'll feel better and the "pings" will go away.
I have the same issues, I hear gear whine every time I get done with a healthy 1-2 shift. It goes away after I do a spray detail on the chin spoiler.
Old Apr 16, 2008 | 09:33 PM
yeah thats what im hopin
Old Apr 16, 2008 | 09:45 PM
ryan1112's Avatar
It really sounds like its the exhaust cooling. Could the long tubes be really close to the heat shields causing the shields to ping from cooling.
Old Apr 16, 2008 | 09:54 PM
ive been under there a bunch of times and they fit pretty much where the stock pipes were, like i said this hasnt been a problem until a couple months back............ right now im thinkin exhaust leak eventhough i tightened it up... bottom line im confused and hoping its not anything bad
Old Apr 17, 2008 | 01:42 AM
theedge67's Avatar
Could be exhaust leak, that would make sense. Even a tiny one will make noise, and they can sound different depending on where they are and how bad they are.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
