The Parts are arriving Daily.Wont be third for long.
Old May 4, 2006 | 07:51 PM
mikem's Avatar
Well the car is torn apart this week.Parts that just arrived.HookerSupercomps LT,s with matching X-pipe(offroad),Uderdrive Pully,4.30 gears,Tru Track Posi unit,A/C Delete Kit,And removing Weight everywere posible.Battery moved to trunk.
Waiting for Complete race rims with tires,Fuel pump,Driveshaft,Heavyduty Clutch.
[img]style_emoticons/<#EMO_DIR#>/banana.gif[/img] [img]style_emoticons/<#EMO_DIR#>/banana.gif[/img]
Old May 4, 2006 | 08:27 PM
Bingo's Avatar
Those are sexy Hookers. How was the install?
Old May 4, 2006 | 08:30 PM
emperorjordan's Avatar
hey, I have been ,meaning to ask you, got any bigger pix like your avatar?
and i want pix of the car with the new wheels please...
Old May 4, 2006 | 08:44 PM
max2000jp's Avatar
Mike...Don't know if it's fully installed by the pics, but how does the new combo sound? You and I both had a MAK OR/Magnaflows and I am considering Hookers, so I need a full report!
Old May 4, 2006 | 09:22 PM
dustindu4's Avatar
9 is not my lucky number.
I'm sure it will sound sick
Mike you got that video of my stuff yet?
Old May 4, 2006 | 10:42 PM
max2000jp's Avatar
<div class='quotetop'>QUOTE(dustindu4 @ May 4, 2006, 10:25 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I know u added an H...How is the sound? Does it sound like a truck under partial throttle?
Old May 4, 2006 | 10:57 PM
dustindu4's Avatar
deeper and more growl than the X-pipe u have
Mike had the same setup as you: C&L Intake, MAK Offroad X-pipe, Magnaflow Axle-back and I know exactly what your car sounds like.
Old May 5, 2006 | 04:18 AM
mikem's Avatar
Dustins car is very deep and louder with the offroad and Flowmasters.
I worked on the video last night Dustin but had some dificulty.i will post it today.
Headers are not to bad to install.
Old May 5, 2006 | 08:13 AM
max2000jp's Avatar
<div class='quotetop'>QUOTE(dustindu4 @ May 5, 2006, 12:00 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
See the problem with that setup and you've probably heard it is that it sounds "like a pickup" under partial throttle. It's only present in the lower rpms, maybe 1,500-2,750. I've had a bunch of friends tell me that from outside the car. They do say it sounds great when you get on it. I am trying to decide what product to buy and was thinking of an H or Hookers/X. Maybe Mike can chime in and tell me his thought.
Old May 5, 2006 | 08:54 AM
dustindu4's Avatar
I actually like your combo but it sounds like a Corvette and not a mustang. Too raspy.
I'll wait to see what the hookers sound like.
Old May 5, 2006 | 08:59 AM
2006GT500's Avatar
Did you have any problem with the header bolts by the motor mounts? How did you go about getting them in. Mine are in but I don't think they are as tight as they should be.
Old May 5, 2006 | 10:53 AM
mikem's Avatar
<div class='quotetop'>QUOTE(2006GT500 @ May 5, 2006, 10:02 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I removed the Motor Mounts to do the install.way easier.
Old May 5, 2006 | 08:28 PM
mikem's Avatar
Install Tips.For the Supercomp Headers.
Do one side at a time.Take out motor mount and leave other side in.Jack Engine up slightly and take out the Motor mount and bracket.makes life simple.Passenger side is easy.Driver side is a little more tricky.Undo Steering shaft.I had to take out both bolts to get it undone.Directions dont mention that the Oil Dipstick has to come out also. Dont tighten bolts untill all are in.I also removed battery and tray for easy access to everything on that side.people say you can undo the green O2 censors without battery out but,Much easier when its out.Most Bolts are 13 and 15mm.Factory manifold nuts are 13 and the studs are 5.
They look awesome.
HoosierDaddy
Sep 22, 2015 03:18 PM
Sep 10, 2015 08:31 AM
GMAYS
Sep 10, 2015 06:19 AM
Steve@CJPP
Sep 3, 2015 10:43 AM
