Painting your Valve covers
Old Jan 13, 2008 | 08:07 PM
monster693's Avatar
Have any of you guys painted or changed your valve covers on your 4.6. If you have what color did you go and did you have any problems? Also if I pull mine off is the factory gasket reusable?
Old Jan 13, 2008 | 08:31 PM
DavidM's Avatar
I've done it. It's easy. Used High heat spray paint and high heat clear. The gasket is reuseable. Do a search there should be lots of info on this.
Old Jan 13, 2008 | 09:45 PM
SoundGuyDave's Avatar
Just a few additional pointers. The gasket is resusable, but take a little care when pulling the old ones off. There is a bit of silicone used in two spots on each side, right where the front timing cover mates to the cylinder head. You'll need to gently peel this stuff up, spray with silicone gasket remover, and use a PLASTIC scraper to remove the balance fo the residue. Add a couple of new blobs of RTV Black gasket maker, and you'll be fine. Once you're done painting your covers, you may want to hit them with a coat of wax, to keep the paint maintenance to a minimum. Also, use blue painters tape to liberally cover the pieces while you're doing the install so that you don't scratch and scrape your clean covers up on wiring harnesses, etc.
Old Jan 13, 2008 | 10:14 PM
GRAYPNY's Avatar
I just had mine powdercoated. $100
Old Jan 13, 2008 | 10:23 PM
Ray Man's Avatar
Those are sooooo pretty!
Old Jan 14, 2008 | 10:23 AM
Torched05stang's Avatar
I painted mine........
1. Used etching primer.
2. Reg. automotive paint (same as body)
3 I install my custom decals then cleared over them.
Sorry, I didn't take any pics before installing on the engine.
Old Jan 14, 2008 | 10:30 AM
GTJeff's Avatar
Yes... Just like DavidM said...
Old Jan 14, 2008 | 11:00 AM
Embalmer's Avatar
I had mine powdercoated as well. Much more durable than paint!
Old Jan 14, 2008 | 11:05 AM
jayguy's Avatar
I had mine powder-coated also, Agean Blue.
Old Jan 14, 2008 | 11:52 AM
n8rfastback's Avatar
pc is the way to go!
Old Jan 14, 2008 | 12:02 PM
NYNY53's Avatar
Rich they look fantastic!
Old Jan 14, 2008 | 12:33 PM
Ford Racing 3-Valve Cam Cover install
Old Jan 14, 2008 | 01:26 PM
06stage3's Avatar
Powdercoated red....Only issue was the throttle body location on the Roushcharger...
Old Jan 14, 2008 | 02:54 PM
06GT4RAD's Avatar
Buy new gaskets it cheap insurance.
Old Jan 14, 2008 | 04:19 PM
70MACH1OWNER's Avatar
Hey Rich....Those look awesome!!!!!!!!
Scott
Old Jan 14, 2008 | 07:48 PM
anthony05gt's Avatar
I painted mine old Ford blue $3.95
Old Jan 14, 2008 | 09:41 PM
GRAYPNY's Avatar
You can buy new gaskets if you want but these gaskets are hard to screw up and are very pliable. Save yourself $24. I bought them just in case and returned them today for a refund.
Old Jan 15, 2008 | 12:58 AM
Ray Man's Avatar
Dang Jeff...
Old Jan 16, 2008 | 07:59 PM
monster693's Avatar
Thanks guys. I work at a paint manufacture and distributor so I have been deciding between a high temp paint we have or powder coat. My biggest questions were if the gaskets were reusable or not and how much of a ***** it would be to take them off. I think I am going to powder coat them red.
May 3, 2026 05:42 AM
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
Cobiecane
Oct 23, 2015 08:44 AM
GLOCKer
Sep 28, 2015 05:20 PM
