Ordering gauges-quick question
The gauges that I want are below. I just want to make sure that these are the gauges that I will need for my paxton 2200 system. The wideband says that it does not work with the OEM senders, does anybody know what that means. Will I need to order anything seperate to install these or do they come with everything I will need to install them. I want the mechanical boost right. I will not be going with a fuel pressure gauge. Thanks
-Adam
http://egauges.com/vdo_mult3.asp?Typ...balt &Units=E
http://egauges.com/vdo_ind.asp?Type=...lt&PN=ATM-6107
-Adam
I will be ordering those but i can't decide if i want the fuel pressure gauge. I am getting the sos gauge pod but I do not like the way the triple pod looks
1500 posts....Watch out!
You know, you could always do one or two Aeroforce gauges- two of them would cost about the same as what you're looking at now but they would allow you to monitor dozens of parameters, and display four readings (two per guage) at a time.
If you haven't done so already, check out this thread:
http://forums.bradbarnett.net/showth...ight=aeroforce
I believe there is a phone number in this thread for Todd at Aeroforce- they are awesome guages. Like to do your air/fuel, you would need to buy the sensor and to do fuel pressure, you'll need to add a sender kit which I think is like $60. But, then you could do battery voltage, ambient air temp, air/fuel, boost, fuel pressure, intake air temperature, timing, etc. etc. etc.
I think i'm gonna just go with a boost/fuel gauge. I am only aiming for 430rwhp and I can always get the wideband later on. Seems like the boost and fuel pressure are two of the more closely monitored gauges associated with supercharged stangs
9/10/15 12:44 PM
