Ok, which T handle for the Hurst shifter
I got the hurst shifter with the white ball in my car. I want to go with the T handle ****. But which one do I order?
3/8 - 16
12mm / 1.75
3/8 - 16
12mm / 1.75
I ordered the metal t-handle when I ordered my Hurst shifter, because I had something similar in my car back in the 70s. But while it looked cool, I found the feel in my hand weird when shifting at the drag strip. So I pulled it off and replaced it with the white ball that came in the box.
Oh, note that it got REAL hot in the summer, and freezing cold in the winter!
John
John
The white ball rocks! Get ready for aluminum shifter hell in the summer. You also have to completey re-learn how you shift because of the shape. You'll probably find yourself holding under then shifter and using the shaft.
I have the Hurst handle on my car as well. I had the T shifter on it originally. It looked cool but was problematic shifting at the strip. I went to a white ball and have had no further issues.
