OIL
Originally posted by mikem@May 25, 2005, 8:51 PM
Ford and most other auto Manufacturers have spent billions in engine research and development.Sticking to there recomendations and Viscosity.s is all you need to do.Dont get stinked into gimicks that actualy might hurt your performance and engine.
Factory semi-synthetic, factory suggested drain intervals - you can't go wrong. Anything else just increases your cost of ownership. I am guilty of falling for the synthetics in the past, I did run mobil 1 in my last car on 10k drain intervals even with an 11.5:1 compression ratio, an 8100 rpm redline and 100 hp per liter :R: The compression was still good as new at 90k on that car though. The tech was amazed but not surprised, he had just seen the same model car with 130k miles that used factory oil changed at 10k and it was no different...to each his own but what it all boils down to is there is no right or wrong choice here.
