Noise coming from rear end?
Old Aug 20, 2010 | 11:00 PM
MUSTANG4LIFE's Avatar
Just had professional shop change out stock gears in my 06 gt auto vert. Hears my NEW problem. When traveling at low speed about 10-20 mph and I turn at a light or pull into a parking space, I hear what sounds like a whining noise come from the rear end. I don't hear it going in a straight line or when I am at speed 55 or over. You know something's up when the wife mentions a noise as well.
Please respond as to what this probably is. I did not have this issue whatsoever before the gear change. Oh and I took the car back to the shop(great place and they will do what it takes to make it right!) and I went with the mechanic and couldn't get the freakin' thing to make the rear end noise. So, sometimes I get noise when turning and sometimes I don't. HELP! ideas?
Old Aug 21, 2010 | 08:18 AM
tdbrown75's Avatar
Two possibilities I can think of. As it's only happening during low speed turns I'd look to the differential as the source of the problem.
The first possibility is that your differential clutch pack is worn and needs to be replaced. There is a TSB for this, should be easy to find. When I had my gears done I had a new clutch pack installed as mine had started doing the same thing prior to the install.
More likely (since it just started happening after gears install) the shop did not use friction modifier or the proper amount of friction modifier when they added the fluids back. You need to ask about that, without the friction modifier the clutch packs will "chatter" or "whir".
Tim
Old Aug 21, 2010 | 08:38 AM
tdbrown75's Avatar
Here's that TSB: https://themustangsource.com/galaxie...xelchatter.pdf
Tim
tukatz
Oct 13, 2023 10:01 AM
Ecostang
Nov 3, 2022 08:50 PM
SpeedyJoe
18
Aug 23, 2015 02:42 PM
Kev006
Jul 8, 2015 05:29 AM
