Nitto 20" tire question
How much air pressure do you run in Nitto555 20 inch tires? It says on the side, do not exceed 40psi to seat the bead and then has a max pressure of 50psi. Discount tire put 30psi in them and they look under inflated to me. Also I have TPMS sensors, will they be damaged with a higher air pressure?
I run 28 PSI cold on the "around town" street just to soften up the ride a tad. On a trip I would pump them up to 32 PSI cold.The ride is compromised anyhow with 19s or 20s.........
That's cool, just wanted to make sure they were not underinflated. Made me a little uneasy with only about 1 inch between the pavement and my rims.
