Next mod?
Old Jul 10, 2012 | 06:34 AM
muscledom's Avatar
Next mod?
Im between long tubes, rear control arms, and a 2 step. thoughts?
Old Jul 10, 2012 | 08:20 AM
Agent MOO's Avatar
I'd be interested to hear opinions on an MSD 2-step. Is it considered cheating? Also does it ever activate when you don't want it to?
Over the winter I did the BMR LCAs and they have made a big difference in stopping the awful wheel hop that I've had since I bought the car. You'll be amazed at how flimsy the OEM pieces are when you pull them out.
Old Jul 10, 2012 | 09:18 AM
muscledom's Avatar
Yea the control arms are tempting. As far as the 2 step, I think it can only activate if the clutch and accelerator are both to the floor.
Old Jul 10, 2012 | 09:39 AM
Agent MOO's Avatar
Ah I see, so basically it stops cutting gas once you begin to disengage the clutch. I was over-thinking how it activated and thought it had more logic to it
Old Jul 10, 2012 | 09:48 AM
muscledom's Avatar
Yea I guess it's a piggy back thing. It hooks up to the coils and I'm guessing the PCM.
Old Jul 10, 2012 | 09:52 AM
Agent MOO's Avatar
Some good Pro/Con discussion: http://www.mustangevolution.com/forum/f358/t298148/
And a layman's description from http://www.camaro5.com/forums/showthread.php?t=220223
Say you set the two step to 3000. Let the engine drop back to idle, depress the clutch, and rev the engine to the 3k limit. The limiter will not disengage until the clutch is fully released. It will not reactivate until you let the engine slow back to idle.
Old Jul 10, 2012 | 10:34 AM
dirtfan71's Avatar
I've been looking at this instead of MSD 2-step.
http://www.npcompleteperformance.com/wotbox
Old Jul 10, 2012 | 01:18 PM
roberts's Avatar
Dont get the mSD 2 step get n2mb wot box I have one and love it! No lift shift is BA.
N2mbracing goggle search
Worth the $200 every bit! !!
Old Jul 10, 2012 | 01:33 PM
muscledom's Avatar
Cool thanks for the heads up, I will definitely check in to it
Old Jul 10, 2012 | 01:38 PM
Agent MOO's Avatar
Can you tweak it without using a computer? I picture a laptop flying around during a drag run
Old Jul 10, 2012 | 02:31 PM
muscledom's Avatar
Either that or you'd have to mount that ***** like a state trooper lol
Old Jul 10, 2012 | 02:45 PM
roberts's Avatar
You can but it's a pain in the butt without a labtot!!
Old Jul 16, 2012 | 03:20 PM
Doug@C&L's Avatar
Been there, done that
Actually the passengers seat belt holds them down just right, but trying to read them while driving/racing is NOT GOOD!
TripleBlack14
May 10, 2016 04:30 AM
Bryanh24
Oct 14, 2015 08:43 AM
