New QA1 struts
Old Feb 9, 2007 | 10:04 AM
169stang's Avatar
New QA1 struts
Here's some pics of the new QA1 struts that BMR carries. The OEM strut w/a Steeda Sport spring weighs 23lbs. The QA1 struts weighs 14lbs. You buy the struts, springs, caster camber plate all seperate. All together, you can adjust the caster, camber, ride height, and the actual shock rate (soft to stiff). It took me about 30 minutes to install both sides. I just need to get an alignment now.
http://bmrfabrication.com/2005MustangSUSPENSION.htm
Attached Thumbnails New QA1 struts-new-front-end-007w.jpg   New QA1 struts-new-front-end-009w.jpg   New QA1 struts-new-front-end-012w.jpg
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
dohc97
Sep 24, 2015 01:52 AM
Sep 16, 2015 06:44 PM
