New Granatelli Coil packs?
Old Jun 24, 2006 | 11:53 AM
traffic142's Avatar
Question New Granatelli Coil packs?
They claim it gains some HP. Is this just a pipe dream or does it really work?
http://www.granatellimotorsports.com...812CPsmall.jpg
They bolt right in place of the stock coil packs and I know MSD has performance increase by a hotter spark.
http://www.granatellimotorsports.com...connectors.htm
Any thoughts
Old Jun 24, 2006 | 01:05 PM
RPM's Avatar
RPM
This product has been discussed before. IMHO, I don't see how a different coil can improve power in a N/A car that much. The stock system must be really sh!tty, which it isn't. In a modified motor, boosted or sprayed then that is a different story.
Old Jun 24, 2006 | 01:09 PM
Vegasjay's Avatar
I just ordered them from LFP for $349 shipped (For being a member of modularfords.com). I have heard a lot of good things about them from "real" people who have dynoed them. The gains I have read have all been on S/C applications as that's where they are the most help. The best way to make gains with them is to run a larger gap on your spark plugs. I will go from .032 (HTO Plugs) to .038 - .040. The Granatelli coils provide a lot more volts with 0 resistance to prevent spark "blow out" witch is what happens when you have larger gaped plugs in a S/C application. By allowing you to gap out your plug's you gain horse power...They say you can gain up to 15 HP on a N/A car but I haven't seen it personally, not saying they won't. This seems to be a much better "real" performer compared to let's say the Billet T/B's or spacer's...IMO I'll see for myself shortly.
Old Jun 24, 2006 | 08:16 PM
mikem's Avatar
I definately felt more crisp power just running normal.have not tried with the Nitrous yet.But i am going to the Dyno soon to tune everything.
Old Jun 25, 2006 | 05:30 PM
Gibbo_UK's Avatar
Hi m8
Are you running an NA car? If so you saying it feels quicker with the Granatelli COPs fitted?
What did you do just fit them or did you adjust your spark plug gap too in order to get more BHP?
Andy
Old Jul 8, 2006 | 10:13 PM
Granatelli's Avatar
Former Vendor
Without jinxing myself, our coils have been very well received. This is no gimmick. Everyone that tries them say the same thing. Better idle, smoother running and YES more power. Sure they have been dyno proven on tons of forced induction motors and YES they will always make more power (increase I mean) when the ignition is taxed more – like in the case of supercharging, turbo or nitrous. On a stone stock motor, you are probably correct on the first dyno pull the stock stuff can hold up. Now keep the hood shut and make six pulls in a row with the stock stuff. The stock coils have no endurance. They heat soak and wimp out. The GMS coils will continue to output the max voltage required over and over.
MSD has tested our parts on their dyno and have had the same results as all of you.
We have several customers with beefy N/A high compression engines that report power increases over the stock coils day in and day out
Old Aug 8, 2006 | 06:59 PM
Granatelli's Avatar
Former Vendor
Just Dyno tested a Ford Gt with our Coils and Wires
This car has a Kenne Bell 18 PSI blower snout and a Fuego re tune. The car was brought to us with the snout already installed so I never got to dyno it stone stock. He putted it in and we wrote a tune for it. After we got it dialed in we then did the coil install with wires - they are the results
16hp and 28 ft/lbs
Old Aug 17, 2006 | 12:17 PM
Granatelli's Avatar
Former Vendor
http://www.granatellimotorsports.com/video14.htm
here is the video back up
GeoWett
Sep 30, 2015 06:40 AM
UOP Shadow
Sep 27, 2015 07:24 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
Fred_Garvin
Sep 17, 2015 04:10 PM
earl610
Sep 6, 2015 05:48 PM
