new built shortblock
Old 12/8/05 | 05:05 PM
169stang's Avatar
Here's a few pics of the new built shortblock. The valves will be seated in the heads tomorrow and the longblock should be done next week.
Old 12/8/05 | 05:08 PM
169stang's Avatar
[attachmentid=40386]
turboshortblock on left, nitrous shortblock on right
[attachmentid=40387]
Old 12/8/05 | 05:15 PM
169stang's Avatar
Old 12/8/05 | 05:17 PM
169stang's Avatar
OEM valves and springs
[attachmentid=40391]
[attachmentid=40390]
Old 12/8/05 | 05:20 PM
169stang's Avatar
the aluminum block is a nitrous shortblock
[attachmentid=40393]
[attachmentid=40392]
Old 12/8/05 | 05:22 PM
gt6974a's Avatar
What are the oem valves and springs built with compared to the new ones?
Looks cool, but whats with all the blocks? Do you do this for a living?
169stang's Avatar
[attachmentid=40395]Nitrous shortblock...notice the flat-top piston for higher compression.
[attachmentid=40394]
Old 12/8/05 | 05:28 PM
169stang's Avatar
Uh no, this is in my motor builders shop-Al Pappito Boss 330 racing. My shortblock is the black iron one which is being built for a turbo setup. The aluminum block is being built for Nitrous. Different material in the valves and springs. The custom springs are a double spring. A bit more reliable. The pistons on mine have a 9cc dish where the nitrous piston is flat. The valves going in mine are flat on the bottom compared to the oem ones. So..the pistons are dropping the compression a bit, but the valves, being flat, will bring it back close to OEM compression. With the buildup being a turbo setup, the motor will MAYBE p/u 5-10 hp without the turbo of course. Better balancing and rotation. The motor will be able to spin at about 9000 rpm's safely...if I wanted too, but I won't.
Old 12/8/05 | 05:42 PM
Sonic Brew's Avatar
Looks awesome, good luck with it.
Old 12/8/05 | 05:49 PM
Mongoose's Avatar
Daved.What is the deplacement of this motor?
Old 12/8/05 | 06:03 PM
169stang's Avatar
bored .020 over
Old 12/8/05 | 06:45 PM
creedog's Avatar
Looking sweet David.
Can you PLEASE give me ride in that thing when you are done!
Old 12/8/05 | 06:52 PM
Black3V's Avatar
darn boy looking good. Lemme know when this is going to go back in and ill be there. So what happened to no overbore?
Old 12/8/05 | 06:56 PM
Vegasjay's Avatar
Looking good David... Did you buy the block thru FRPP and then take it to Al? What did the block by itself run?? I've been looking at the 5.4 L Iron block, it's just so heavy...
Old 12/8/05 | 07:30 PM
HTownStang's Avatar
Nice it going to be a monster. how much does it cost for total build?
What sleeve are you have on your block?
why are you not using the stock block?
Did you ask them how many HP can the stock block hold?
Old 12/8/05 | 07:36 PM
dustindu4's Avatar
9 is not my lucky number.
That is going to be one FAST car
Boss 330 Racing does not mess around
Old 12/8/05 | 07:40 PM
88blownstang's Avatar
I'm curious, why did you go with iron over aluminum like the nitrous block? That forged crank looks stout. You said you could rev to 9K if needed, what type of rods? How much boost are you going to run? Sorry for all the questions. I am new to the mod motors and trying to learn as much as I can before spending $$$. Thanks! Bob
Old 12/8/05 | 07:42 PM
jp's performance's Avatar
Originally posted by Blazing Saddles@December 8, 2005, 8:35 PM
With the turbo it looks like you're going to have the quickest 3V Mustang. Sutton Take Notice.
mine won't be done till next summer (unless i win the lottery) would be happy to go 10.80's on radial's and drive home. :worship:
Old 12/8/05 | 07:44 PM
ZwerRacing's Avatar
What type of turbo setup are you going with? Custom, powerhouse, hellion? I know there are more but those were the first three to come to mind.
Quick Reply: new built shortblock
