Need Technical Assistance
Old May 30, 2007 | 05:38 AM
kryptonite's Avatar
OK, here is the deal. AND I am not seeing much help from either JLT or SCT, so I am turning to my mustang breathern.
I installed the JLT CAI on my 05 Mustang GT. Uploaded the tune from my xcal2. I started with the 87 tune to see what I would gain. I am experiencing pinging when I shift from 1st to 2nd and 2nd to 3rd @ around 3500 rpm. I first thought I got a hold of some bad gas (insert joke) and tried a couple different gas stations with no change in the result. I then bumped it up to 93 tune and get the same problem.
JLT tells me to contact SCT, since they were the ones who built the tunes they supply. SCT replied once to my post on their forum, but have not heard a response to my response.
Can anyone make any suggestions and help me out with this? I'm fairly certain the car is running lean and that is my problem.
Old May 30, 2007 | 05:55 AM
pville piper's Avatar
The way I see it you have 3 options:
  1. Return it to stock - pinging is never good in an engine.
  2. Using your Xcal2 retard the timing advancement a bit thru the timing ranges. Don't add fuel just retard the timing.
  3. Get it custom tuned or contact a custom tuner like Doug at Bama Chips, CR a Tillman Speed and Brenspeed. The custom tunes that they or a good local shop do much more than the canned tune and you will get much better cutomer service than what you are getting.
Old May 30, 2007 | 06:29 AM
tom281's Avatar
+1 that's what I would do.
Old May 30, 2007 | 07:11 AM
kryptonite's Avatar
Thanks for the info.
I sent a note to Doug to see what he can do.
Old May 30, 2007 | 08:37 AM
TillmanSpeed's Avatar
Former Vendor
Thanks for the plug. Definetly hit myself or Doug up for a custom tune. It's always possible you got some bad gas amidst all of the controversy, but if you still have problems even on the 93 map, it's the tune.
Feel free to give me a call. Thank you sir!
CR
Tillman Speed
610-497-3711
Old May 30, 2007 | 01:52 PM
kryptonite's Avatar
CR. I sent you a PM.
Old May 30, 2007 | 06:46 PM
DynamicmustangGT's Avatar
CR will get you setup the right way.
Old May 31, 2007 | 06:39 AM
kryptonite's Avatar
I did #2 (-1 degree) and so far, I don't hear the pinging. We'll see how things turn out. THX!!!
kponypower
Jun 17, 2020 07:17 AM
earl610
Sep 6, 2015 05:48 PM
Sep 2, 2015 07:33 PM
HizliBullet
Sep 2, 2015 06:58 PM
