Need some help fellas...
Old Jan 9, 2009 | 12:35 PM
EagleStroker's Avatar
I don't do trannies
or rear-ends anymore!
Ok, picked up a raptor from Tom in his garage sale and have been working on installing it. I ran a fuse tap out of the passenger side fuse bog for my hot wire to a switch in my console. Tapped the coil, saudered all my connections. The switch i'm using requires a ground so I did that and went to finish the ground wire for the raptor but that caused my switch (it has a light) to go dead, i'm on electrician but I'm guessing I only need one ground. I know I'm getting power and to the Raptor itself, but I've got a problem either with my connection to the coil itself or grounding the Raptor.
Any help would be appreciated it, I searched through quite a few threads but no one's done anything like this that I've seen.
Old Jan 9, 2009 | 04:31 PM
classix_stang289's Avatar
what i usually see at my dealership(lexus) with some people who bring there cars in with some aftermarket stuff is a very bad ground connection.
i guess that would be a good starting point, other than that dude i dont know sorry.
Old Jan 9, 2009 | 04:33 PM
I don't do trannies
I know I'm getting a solid ground, took the tester to it (I clamped it on the bolt for the e-brake) I need to check the power output from my fuse tap, kinda hitting my head for that one. Any more suggestions are welcome
Old Jan 9, 2009 | 04:37 PM
what is the fuse rated at? maybe too much juice for the fuse?
Old Jan 9, 2009 | 04:43 PM
I don't do trannies
Hasn't blown it, it requires a 12 amp power source and I swapped in a 20 amp fuse to make sure that wasn't the issue. Plan on using a 15 when it's all together.
avinaj80
Jul 2, 2011 03:53 PM
avinaj80
Sep 24, 2009 05:49 PM
