Need help from those with CAI
Old Dec 20, 2007 | 01:09 PM
Embalmer's Avatar
I have a Tuneable Induction CAI from DeMolet and I'm having some engine parts powdercoated. I sent the heat shield from the CAI with the parts to get coated and apparently whatever metal it's made from cannot stand up to 390 degrees, so it melted. Can anyone out there give me measurements so I can fabricate another? I have pics, but having the actual measurements would make it much easier. Here's what I need the measurements on, the heat shield around the filter:
Thanks!
Old Dec 21, 2007 | 05:36 AM
colbymh's Avatar
I will check mine later today. I have a Steeda CAI, but the heatshield is similar.
Old Dec 21, 2007 | 07:42 AM
brian2906's Avatar
James,
I have a Demolet TI CAI, but the heat shield is made from a heavy lexan type plastic. It does look just like yours, and I'd be happy to measure it when I get home this afternoon.
Old Dec 21, 2007 | 10:07 AM
Embalmer's Avatar
Thanks! We were under the impression it was really thin metal. Oops!
Old Dec 21, 2007 | 01:12 PM
Pwny's Avatar
Ouch
Old Dec 22, 2007 | 09:15 AM
brian2906's Avatar
James,
Sorry I didn't get the chance to check it last night, besides it was cold out! This morning it's 62 already in St. Louis. This may be tough to describe, but I'll give it a shot. Starting with the side that the intake pipe goes through, it is 10.5 " across. 5.5" high at each end, with a height of about 8" in the middle. the hole is about 5" in diameter. The other side is 12" wide at the top, 4.5" high where it bolts to the fender, and stays 4.5 " for 3" before it angles down towards the corner where it is 8.5" high for 3" where there is a .5" 'cutout' on the bottom (8" high) for 3" until it meets the other section at the corner. I sure hope this helps, talk about a pix being worth 1,000 words!
14_GT/CS
2011 - 2014 GT/CS
12
Mar 24, 2016 12:20 PM
MustangConvert11
Sep 30, 2015 08:01 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
Stephen Laslo
V6
Sep 18, 2015 07:57 PM
TripleBlack14
Sep 17, 2015 07:48 AM
