Need help/advice removing over axle tubes
Old Aug 14, 2011 | 09:28 AM
05GT-O.C.D.'s Avatar
I lust for a M24
I've done this before, and I remember it being a PITA, but I can't remember how to re-install the over-axle tubes. I've got the rear suspension completely unloaded, but can't seem to get enough clearance. Is there something I need to unbolt to get it to drop lower? (FRPP springs BTW)
Old Aug 14, 2011 | 09:57 AM
take the lower bolt off of the shocks. That should allow a little more room. Watch your brake lines and such when lowering the rear axle.
Old Aug 14, 2011 | 10:18 AM
I lust for a M24
Yup, just completely unloaded the rear axle. Removed the shock bolts, removed the sway bar links. Just not enough room. I think I need to get the front end up higher. What a PITA!!!
Old Aug 14, 2011 | 07:24 PM
BaknBlk's Avatar
Maybe I got lucky then. I didn't raise the front at all and just used jack stands for the rear. I do remember the passenger side went in very easy, the drivers side gave me a problem. The pipe was stuck between the shock, rear axle and the frame, kind of wedged in there...I got tired of fighting it and gave it a good hit with the rubber mallet and it popped over. Wish I could be more help....good luck.
Old Aug 14, 2011 | 08:04 PM
I lust for a M24
Thank you sir. I've been working on the right side. I'm going to try again tomorrow, but I'll try the passenger side first tomorrow.
Rando
Aug 25, 2021 11:12 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Sep 24, 2015 08:15 PM
Sep 10, 2015 12:44 PM
