need clutch help!
need clutch help!
I'm getting a new clutch and flywheel in my 06 GT but im having a hell of a hard time deciding which clutch. I like the Fidanza aluminum flywheel. As for the clutch I have no idea, Ive heard good and bad things about all of them. So far im deciding between the Spec, Centerforce, or Mcleod. I need some opinions, please help me I have to decide by tomarrow. My car is supercharged and makes about 420rwtq right now and I take it to the track a lot. Thanx for any replies
I recommend the McLeod unit!. Either the Super Street Pro or you can get the twin disc new RST unit that will hold 800hp with pedal pressure that is lighter than stock!!. I have it in my car and its simply awesome. PLus, with the RST unit you have the choice of using their flywheel, any other flywheel on the market OR your stock flywheel if you want. They have a special ring which allows the clutch to bolt to ANY flywheel!. So technically if your flywheel is good (probably) , you can have a big holding power clutch without having all the extra expenses that typically come with them
9/23/15 03:21 PM
JonathonK
9/19/15 03:19 AM
