MT ET Street Drag Tires 26x11.50-17
Just mounted my ET Drag DOT,s on my new set off factory rims.Was worried that they would be to big, because they say minimum rim size 9.The factory,s are 8,But they fit Perfect.Same height also.A little wider on the contact area.Took for a ride but,It is raining out right now.These are the Biasply type.No tube required.On the photo in Summit Racing they say tube required.But when i called they said they dont.When they arrived it clearly says tubless on them
Setting car up for friday night at New EnglandDragway.12,s hear we come.....
Just incase anyone wants hear is the part numbers MTT-3743 is Bia-ply and MTT-3743R is Radial.Radials are on backorder.
[attachmentid=24581]More
another
Originally posted by Blazing Saddles@June 15, 2005, 5:33 PM
I'll see you there Friday. BTW. My Bogarts were supposed to ship last Friday. Now they tell me next Wednesday.
George, that' not what I want to be hearing right now!!! I'm still 3-7 weeks out. 1 week down and forever to go. You guys have fun! I went tonight. Ran a 12.88@106 on a 12.9 dial in. Couldn't hook up to well. I usually launch at 6000 rpm, but due to conditions, was launching at 5400 rpm. It was HOT today and humid (about 85%). Just a bad air day. I still need to make some changes to my rearend. My pinion angle is at -1.9. I just need to get it to -2.5 degrees. I tried to change it earlier today from jack stands and it's tight with the exhaust in the way. Not even enough room to turn a wrench (1 1/2" nut). Besides, I only have 1 of those wrenches and I need 2.
Sep 16, 2015 06:44 PM
Sep 8, 2015 10:45 AM
Cdvision
Sep 5, 2015 05:22 PM
