Moroso Catch Can up close
I purchased the Moroso Catch Can from Lethal Performance here are some pictures. I'm going to install it in the next month or so as soon as I get a custom AN fitting that is being made for the Kenne Bell blower.
The kit includes... http://i170.photobucket.com/albums/u...n/IMG_7198.jpg http://i170.photobucket.com/albums/u...n/IMG_7193.jpg http://i170.photobucket.com/albums/u...215_resize.jpg http://i170.photobucket.com/albums/u...n/IMG_7209.jpg This unit is actually for the Hemi Charger but with a little work it will work fine for the stang. The two side holes use a 3/8 NPT. http://i170.photobucket.com/albums/u...n/IMG_7199.jpg http://i170.photobucket.com/albums/u...n/IMG_7201.jpg http://i170.photobucket.com/albums/u...n/IMG_7205.jpg I plan to replace the supplied brass hose fittings and go with AN fittings (Mr Gasket/Shadow Series) and a breaded line from Airoquip. http://i170.photobucket.com/albums/u...n/IMG_7192.jpg http://i170.photobucket.com/albums/u...n/IMG_7212.jpg More to come after the install stay tuned. Jed |
Looks nice. How big is it? Looks like a couple inches judging by the pic.
Originally Posted by LEO_06GT
(Post 5771666)
What is this, an oil separator for the PCV circuit? How much?
Thats nice! What do they cost??
Thanks for sharing as I have been searching for a small, but decent quality catch can and this one meets both those requirements :nice:
Please keep us posted on how the install goes! |
This has your name all over it Doug! Looks great Jed :nice:
Looks like UPR's, but smaller - with a drain plug & hose.
Originally Posted by EagleStroker
(Post 5771708)
Originally Posted by 06GT
(Post 5771679)
Originally Posted by IHVOCD
(Post 5771686)
I think it cost me $145.00 for the "kit" a little pricey but it met all of my install and visual requirements. I've been looking for this for maybe a year; I first saw it at SEMA this year. I bought it from Lethal Performance the stock number is 85472. Jed |
Nice pictures, did you use a light box or just a white paper and good lighting?
Originally Posted by NastyStang113
(Post 5772293)
For those looking for one, go with a BKU oil separator. Brett at BKU will custom make it per your mods. It's pretty identical to the ones you can get from Steeda, however he alters the setup for your needs. Plus it looks good for $45.
How do you get in touch Brett @ BKU ?
Originally Posted by colbymh
(Post 5772336)
(Post 5772336)
Dude there is no comparison to the Moroso unit. This is exactly what I'm getting away from a Home Depot style solution. This is just an off the counter part (w/ to many adapters) that is semi effective and leaky at times if you run synthetic oil. Cost effective yes, but effective MEH. If you're motor is blown that's even more reason not to go down this path. I know a lot of people take this route but it's not for me this unit doesn't raise the bar to me as a separator, plus it's FuGly! http://www3.telus.net/albrecht/oil_s...of_the_box.jpg |
I have the Steeda unit and it is basically the same as the BKU , except it doesn't have the fittings to increasing the size for the larger hoses. It does look like the knob on the bottom is metal on the BKU unit , where as the Steeda one is plastic and has already broken so I don't drain it through the bottom. It's the same size as the Steeda one and I empty mine every weekend to keep oil below the filter and that's only a couple of table spoons of oil. Plus the bowl is plastic and I unscrew it to empty the oil so I'm always worrying about breaking it. Also I had to buy a supply of O rings for it since they don't last long with the oil. I've been planning on changing it for some time and I like this Moroso one the best ...
I am looking into these catch cans.. do you need two? one for each valve cover? i get that from these ebay pictures...
Passenger side http://www.upr-images.com/ENGINE/5032/5032-03.gif Driver side http://www.upr-images.com/ENGINE/503...an-install.gif ?? |
(Post 5772941)
Are you talking about this unit...>
Dude there is no comparison to the Moroso unit. This is exactly what I'm getting away from a Home Depot style solution. This is just an off the counter part (w/ to many adapters) that is semi effective and leaky at times if you run synthetic oil. Cost effective yes, but effective MEH. If you're motor is blown that's even more reason not to go down this path. I know a lot of people take this route but it's not for me this unit doesn't raise the bar to me as a separator, plus it's FuGly! http://www3.telus.net/albrecht/oil_s...of_the_box.jpg Yes, but no. You cant go buy the parts from home depot, because they are not rated for oil use. Now, I cant speak intelligently on the matter, but trust me if you talk to Brett you will not be disappointed. I prefer to see how much oil is going into the catch cup, vs guessing, It's simple to drain and has never leaked a drip. |
Originally Posted by jasongt06
(Post 5772737)
Originally Posted by fdjizm
(Post 5772966)
