MGG shifter won't stay in 4th, Help!
Old Apr 4, 2008 | 06:38 PM
ryan1112's Avatar
I am installing the MGW shifter and when I got it all installed it won't stay in 4th. It just pops out of gear by itself. I tried different throw settings and loosened and retightened everything.
Any ideas...
Old Apr 4, 2008 | 06:43 PM
05GT-O.C.D.'s Avatar
I lust for a M24
When you say throw settings, did you make your adjustments underneath the car, or just to the height of the handle?
Also, you're not using the shift stop kit are you? Did you buy it new? The top of the shifter should be all black and not have two stainless steel plates on top.
ryan1112's Avatar
Underneath the car.
Old Apr 4, 2008 | 06:44 PM
tom281's Avatar
Did you opt to install shift stops?
Old Apr 4, 2008 | 06:56 PM
ryan1112's Avatar
no shift stops
Old Apr 4, 2008 | 07:08 PM
tom281's Avatar
I don't know man, unless you somehow managed to not line up the body with the arm that connects and mounts to the transmission....... just a guess.
Old Apr 4, 2008 | 07:15 PM
ryan1112's Avatar
Also, there is no line on mine to show where the arm should be locked down.
Old Apr 4, 2008 | 07:18 PM
I lust for a M24
No leftover parts?
You've used the washers where required and everything's tightened properly? Don't be afraid to tighten the bolt at the bottom of the shifter where the adjustments are made. Don't let the bushings scare you, you need to get that tight... but don't be stupid about it and break anything.
On the adjustment 'screw' from the underside, it's pointing the correct direction? There's an arrow on it, if memory serves that needs to point to the left (drivers) side of the vehicle. Don't get confused while you're laying on your back.
How many turns out did you unscrew it?
Old Apr 4, 2008 | 07:21 PM
Got Oatz's Avatar
That was going to be my guess, but just that....a guess......
Old Apr 4, 2008 | 09:39 PM
ryan1112's Avatar
Well, I'm stopping for the night.
There are no left over parts. Maybe I didn't lock everything down right. I just need to rest and get a fresh start in the morning.
Old Apr 4, 2008 | 09:58 PM
I lust for a M24
Well good luck, the first thing I'd do before I even grabbed a wrench is try to see what direction that arrow is pointing.
Tomorrow's going to be warmer anyways, and you can see better in the daylight.
Old Apr 4, 2008 | 10:41 PM
shatter's Avatar
Make sure you don't have the shift handle shaft adjusted so low that it hits the shifter base when going into 4th. This happened to me and I would get vibration in the handle in 4th gear like the transmission wasn't fully engaged into 4th. A quick raising of the shift handle solved the issue.
Old Apr 5, 2008 | 06:13 AM
ryan1112's Avatar
FIXED IT
I had the shifter back off the car when I got your suggestions so I'm not sure what fixed it. I just took my time with every bolt, made sure the arrow was pointed towards the driver, and that the shifter handle shaft wasn't hitting.
I just need to reattach the driveshaft, lower it down and test drive.
Thanks for the quick responses and help!
Old Apr 5, 2008 | 06:28 AM
I lust for a M24
Sweeeeet. Enjoy.
Gigantor
May 11, 2023 07:31 PM
Jul 8, 2016 08:53 AM
AdPock
Oct 16, 2015 02:58 PM
09-gt/cs
Oct 15, 2015 10:03 AM
