Metallic Highflow Cats...
Bassani Comp cats, as used on the SS bassani high flow catted x pipe. I have them matched with the factory h-pipe and love the volume and tone. http://www.ninosport.com/Bassani-Met...&category=1074
I might have to get these. did you cut out the stock cats and have these welded in or buy new legs?
the slip fit ends were about 2 inches each side. One flared female, and one male end. I had to have the h-pipe flared to fit over the cat. The length of the cat from end of downpipe to end of H-pipe is 10.5 inches. So total length is about 12.5 inches.
Thats what I should have done in the first place. The only regret I have is not spending the extra $ for the longtubes. Do it once, and do it right, get the longtubes.
I know, I just really wanna keep my prochamber but not have to go through all the hassle of finding the right stuff to go with it being as mac stop making their cats... Might as well buy a whole new setup
In the meantime, I was lucky enough to find a vendor who had one high-flow catted Prochamber left in stock. Which was well over 6 months ago.
Anyway, I'll post the links of the 2 vendors in which I located 6 months ago. And perhaps they just might have a catted Prochamber left in stock. Best of luck to you
http://www.artsperformanceparts.com/...cproducts.html
http://www.laurelmountainmustang.com/index-800.htm
Adam, the reason why Mac discontinued it's high-flow catted Prochamber, was because Catco whom was the manufacturer of their high-flow cats. Refused to honor warranty claims, and then accused Mac of voiding their warranty policy, which supposedly stated that their catalytic converters were not designed to be used for racing purposes. Therefore as a direct result, Mac then decided it would no longer offer catted Prochambers that are manufactured by other companies.
We'll if i could get just the catted legs that would be cool. I'm not trying to buy a whole new prochamber though. Thanks
Has anybody heard of or used these? Eastern Metal Matrix?
http://www.ninosport.com/Eastern-Met...llet-Cat-79125
Adam, when you had mentioned getting a whole new setup. I assumed you meant locating a high-flow catted Prochamber.
At any rate, I now understand where your coming from, and if your willing to pay up to $300 for aftermarket cats. Then of course that always is an option as well. On the other hand, IIRC I believe that Pypes has aftermarket cats for well under $200, so you may want to check out Pypes website and find out for yourself.
Once again, best of luck.
Rando
Aug 25, 2021 11:12 AM
