MAK X-Pipe installed
Old Jun 28, 2005 | 08:28 AM
05mineralgrey's Avatar
Hey all, I just installed a MAK Offroad X-pipe last night, and everything appeared to install fine, and fit ok. Then, I started it up and noticed that the engine compartment is loud now, it almost seems as if there is something way wrong, perhaps a leak? Also, at around 1300-1700 RPM, my whole car begins to vibrate!? None of this happened before, so I would assume it was the xpipe install. If there is any part of metal touching metal on the underside, would this be enough to cause the shaking? or would it just cause rattling?
Any help would be great!
Old Jun 28, 2005 | 08:31 AM
Idrvadodgstr8us's Avatar
Its the big V-8....naw make sure everything is tight and any small leaks will be sealed by carbon build up. It will be a lot louder because you have an off-road...the X pipe will always be loud and more 'tingy' ....i like the sound of an H personally...but thats just my opinion
Old Jun 28, 2005 | 12:28 PM
Thanks for the input. I ended up calling ***** at MAK performance, and he told exactly what was wrong, and why. The crossmember bar bolt was barely hitting the pipe near the hanger, so I Bent it down about 1/4"-1/2", and the problem was fixed. the excessive loudness was all caused by the vibration of the pipe. I havent driven that much, but everything seems to be fine. Ill post a writeup on it later on.
Old Jun 28, 2005 | 01:00 PM
awsome man...maybe a soundclip if we are lucky
Old Jun 28, 2005 | 01:01 PM
max2000jp's Avatar
Are you talking about the hanger? Mine is doing the same thing. The bottom bolt on the right exhaust manifold also keeps coming loose. I am going to have to put some loctite on it.
Old Jun 28, 2005 | 01:16 PM
I will try and put a soundclip of it sometime soon, not sure how, but I will figure it out.
Max2000jp, yes, I was talking about the hangar. On the drivers side, it was aweful, it was hitting a frame bolt right where it hangs in the rubber bracket. On the other side, it wasn't as bad at all, but still there. On that side, the actual metal hanger was hitting on the rubber bracket, So I took a pry bar and hammer, and bent it a little bit back towards the back of the car, this seemed to fix that problem, at least for now. The problem was that it hung so far into the bracket, that the arm was hitting every once in a while.
hope this helps
Old Jun 28, 2005 | 01:23 PM
max2000jp's Avatar
hope this helps
I did the same thing to the passenger side one, except I used 1/4 square tubing and bent it downwards. It worked well, but the bolt on the right side manifold keeps loosening. It causes a slight vibration/rattle when loose and it is leaking. I just went to Carquest and purchase threadlocker, so that should do it.
Old Jun 28, 2005 | 01:31 PM
I hope I do not have this problem, but I might, if so, I will do the same thing. They sure did not make the bolts on the manifold easy to get to on the right side, did they? I had a female dog of a time getting the far right bolt off the first time!
Mr. V
Dec 24, 2016 02:57 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
