Going fully synthetic?
Old Jun 28, 2005 | 07:46 AM
ZeroK's Avatar
Thinking of going fully synthetic. Engine, transmission, rear end. What could I expect for gains by doing this?
Also what weight oil, for the rear. Yes I should probably do a bit more research first, but figured I'd pose the question here. Thanks.
Old Jun 28, 2005 | 08:23 AM
Idrvadodgstr8us's Avatar
at least 50 hp...
Old Jun 28, 2005 | 09:52 AM
y22kc's Avatar
I just recently changed over to full synthetic mobil 1 motor oil Sunday. It was the 3rd oil change, had used Motorcraft 5w-20 on the first 2. Car seems to run smoother to me, but it could just be my head making me think it is :P.
Old Jun 28, 2005 | 09:55 AM
GRAYPNY's Avatar
How many miles before you should change to synthetic mobil 1?
Old Jun 28, 2005 | 10:16 AM
SurfnSoCal's Avatar
Originally posted by Idrvadodgstr8us@June 28, 2005, 7:26 AM
at least 50 hp...
REALLY?
Old Jun 28, 2005 | 10:40 AM
Rebel73's Avatar
Originally posted by SurfnSoCal@June 28, 2005, 9:19 AM
REALLY?
yeah, right! I doubt that. Would be nice, though.
~Rob
Old Jun 28, 2005 | 11:23 AM
MJC302's Avatar
[quote=ZeroK,June 28, 2005, 9:49 AM]
I looked into doing the same. The rear is already synthetic...and with the friction modifier added it probably won't help to change. I called Mobil1 about their synthetic transmission fluid...a no go for the Ford Mustang spec. I would expect 2-5 HP changing the motor oil to synthetic since the Motrocraft blend is only 5-10% synthetic. Good luck with the Royal Purple or Amsoil folks.
Old Jun 28, 2005 | 12:16 PM
i dunno about 50 but i did get at least 8-9 by taking a mist gun and spraying my K&N with water
Old Jun 28, 2005 | 12:50 PM
FRITZ's Avatar
Will it make the engine run more quiet ?.
Old Jun 28, 2005 | 01:04 PM
max2000jp's Avatar
What are you guys using? I know M1 makes a 5W20, but it is hard to find. Murray's Auto had it, but only 2 quarts. Is 5W30 good to use?
Old Jun 28, 2005 | 02:32 PM
PONY XPRESS's Avatar
The best products I have found are "NEO" oils.
They make a 0w-5w engine oil.
They also make a 7w gear oil for trans & rears. It may be called "18" now.
I have used their products in cars with as much as 650hp with no problems.
You will feel a difference.
http://www.neosyntheticoil.com/
Old Jun 28, 2005 | 02:51 PM
y22kc's Avatar
Wow, 0w-5. That's some thin stuff
Rando
Aug 25, 2021 11:12 AM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Evil_Capri
Sep 25, 2015 12:56 PM
