Lower control arms
Old Nov 14, 2005 | 09:46 AM
Klassicyoung's Avatar
Another question guys.
I'm totally ignorant to suspension mods. But seems theres alot of attention to the LCA's I looked at BMR's site. Theres 4 to choose from!
Which do I buy? Race, street, adj? non adj? I want the best bang for the buck, can anyone go about telling me the diff? Thanks. How do they help exactly?
Old Nov 14, 2005 | 09:59 AM
BMR Fabrication Inc.'s Avatar
Is your car more of a daily driver or do you plan on racing more than driving?
Jason/BMR
Old Nov 14, 2005 | 10:06 AM
Daily car. I would like to go to the track once a month or so though. I just wanna kick some cobras hiney lol. looking to get a mean launch some good 60s foot
Old Nov 14, 2005 | 10:14 AM
Eleanor Dreaming's Avatar
Looking forward to this answer. Also, how do we use the discount on the site? Is there a code to enter?
Old Nov 14, 2005 | 10:27 AM
Dubai's Avatar
my car is also daily, but i want a mean 60 ft lunch also,,
Old Nov 14, 2005 | 10:40 AM
dustindu4's Avatar
9 is not my lucky number.
me 4
I want to know too for street use and the occasional track run. Can I just use the cheapie $139 jobbies?
Old Nov 14, 2005 | 10:58 AM
Kluski's Avatar
Sounds what I am looking for. Not serious track time, but a couple times a month. Mostly a fun drving car.
Old Nov 14, 2005 | 11:03 AM
I8URVTEC's Avatar
Might as well count me in on that question too...is it possible that we could get a group buy together if we are all looking for roughly the same thing?
Old Nov 14, 2005 | 12:15 PM
The non adjustable with polyurethane bushings is the best control arm for a daily driver with occasional track time. They are much stronger than the factory piece which eliminates any control arm flexing. At the same time, you are replacing the stock rubber bushings with a polyurethane bushing that won't deflect as much. This combination reduces flex and increases traction.
Jason/BMR
Old Nov 14, 2005 | 12:31 PM
Cleveland's Avatar
I have no regrets with my so-called "noisey" control arms but then again I sprayed mine with WD40 and they dont peep anymore.
-Dan
Old Nov 14, 2005 | 12:41 PM
-Dan
There are a lot of people out there that don't want to sacrifice ride quality for performance. That's why we try to let everyone know that they will be a bit noisier. Glad to hear that your happy with your parts.
Jason/BMR
Old Nov 14, 2005 | 12:46 PM
Cleveland's Avatar
I will eventually have a full BMR Suspension and will share with everybody my awesome experiences with your products.
I must say that the ride quality IMO isnt sacrificed for a daily driven vehicle but I believe my butt has gotten used to it over time.
Also, it would be impossible to hear if they did squeek since I have those Long Tubes and No Mufflers now.
-Dan
Old Nov 14, 2005 | 01:01 PM
max2000jp's Avatar
Jason/BMR
Jason,
What part's do you recommend of yours to improve handling? I go to the drag strip once or twice a year, so I plan on you non-adjustable LCA's with poly bushings to control wheel hop. I do plan on attending 2-3 open track events next year, so I want to make the car a competent handler. Thanks in advance!
Old Nov 14, 2005 | 01:08 PM
creedog's Avatar
Jason/BMR
Jason, Is the upper control arm recommended for a street use only car?
Old Nov 14, 2005 | 01:39 PM
Enter code TMC101.
Old Nov 14, 2005 | 01:51 PM
The upper control arm is not going to help with handling and is not necassary for a daily driver. It is however a big plus to have when you are drag racing. It will stiffen up the factory piece and also helps in eliminating wheelhop. Adjustable version can also help with setting pinion angle.
Jason/BMR
Old Nov 14, 2005 | 01:57 PM
Originally posted by max2000jp@November 14, 2005, 4:04 PM
Jason,
Subframe connectors will help. We will also be releasing our sway bars in a month or so. Besides that, you might want to check into some aftermarket shocks.
Old Nov 14, 2005 | 02:49 PM
creedog's Avatar
Any ideas as far as costs for the sway bars? Those will be for both front and rear? Will they come w/ everything you need? I think Steeda's come as some sort of kit???
Old Nov 14, 2005 | 02:51 PM
No idea on cost yet. They will come with all bushings and endlinks needed.
Old Nov 14, 2005 | 05:44 PM
thump_rrr's Avatar
This is what a set of Lower Control Arms with Poly Bushings look like after 200 runs down the 1/4mi.
If it's wheelhop you're trying to eliminate replace the Third Link with an adjustable one which also has a pinion snubber. This eliminated my wheelhop. I then installed the LCA's more for looks than anything else and you see what they look like after 3 months. This also poses a danger because when I lift off at the end of the 1/4mi. the car wants to head to the right as the rear axle unloads. I have reinstalled the factory lca's for the meantime without any adverse effects to my 1/4mi. times.
