Lower control arm install question.
Old Feb 11, 2010 | 04:51 PM
j0eyabs's Avatar
So I will be installing some lower control arms this weekend and have a question. My question is where do I place the jack to get the rear of the car up in the air? And where should I place the 2 jack stands?
Old Feb 11, 2010 | 08:40 PM
Dysan's Avatar
I jacked mine up under the pumpkin with a wood block (be sure to not lift on the diff cover) and then put jack stands under the axle tubes. You want the rear suspension held in place so it doesn't shift. Just be sure not to put the stands in the way of you doing the remove/install.
Old Feb 12, 2010 | 10:45 AM
MadGT's Avatar
Legacy Tms Member
I agree. Also, you may need an extra set of hands to help you align the axle so that the hole line up without problem. For me, it was not as simple as raising the stang, un-bolting the stock LCA and re-bolting the new one. Maybe I did something wrong, but I sure could have used an extra set of hands.
Old Feb 13, 2010 | 12:18 AM
ManEHawke's Avatar
Tie down straps, if you misaligned it slightly.
Old Feb 13, 2010 | 12:57 AM
JedCranium's Avatar
Follow these ROUSH instruction it should help.
ROUSH LCA install>
Jed
Old Feb 13, 2010 | 01:05 AM
JedCranium's Avatar
You can raise the car from the diff but the car has to rest on jack stands on the frame not the axle. Eventually you will need to raise the axle to align the bolts in the LCA to tighten them, while the car is supported with the stands on the frame. Make sure you are on level ground front to back and side to side. Use wheel chocks on both wheels to keep the car from rolling. Don't use a rock or something stupid like that btw, don't cut corners here on safety, it's you're azz under there!
Jed
Old Feb 14, 2010 | 08:33 AM
MadGT's Avatar
Legacy Tms Member
ROUSH LCA install>
Jed
Good instructions right there...
Old Feb 15, 2010 | 10:11 AM
How I did mine.. Steeda Billet LCA install
Old Feb 23, 2010 | 06:46 PM
bob's Avatar
bob
Just installed the UMI LCAs, Panhard Rod and LCA Relocators, pretty straight forward and easy to do by myself (Matter o' fact the total install turned out easier to do than just the LCA relocators on my GT last time).
The big difference this time I think was leaving the jack under the axle center secion and rotating the jack to help align the axle. The only muscling I really had to do was pull the axle inward about a 1/4 to 1/2 inch as I aligned the lower control arms to the attatching points on the axle.
The only PITA part of the job turned out to be greasing all the zerks since I had an el-cheapo grease gun with a metal tube connecting the cartirdge holder to the piece that attatches to the zerk. Easy fix though, pumped some grease into tube and used the poles for the gate on the fence as tubing bender, then articulated the suspension to get the right angle on the zerks.
Old Feb 23, 2010 | 07:20 PM
MadGT's Avatar
Legacy Tms Member
Hey, glad it worked for you.
Old Feb 27, 2010 | 09:06 PM
pebkac's Avatar
two unsuccessful attempts due to part issues. Had to put the stockers back twice. Stands on frame nothing under axle. Used a ratchet strap to pull the axle forward the 1/8th inch it moved to the rear when I took the LCA out. I will be doing it yet again tomorrow. Should be good this time.
SpeedyJoe
18
Aug 23, 2015 02:42 PM
SMBJoshy
Aug 16, 2015 02:48 PM
Big-D
Jul 27, 2015 11:24 AM
killaz05
Jul 24, 2015 08:49 AM
