Longer Shift Lever
Old Jan 20, 2017 | 02:40 PM
Jack Straw's Avatar
Longer Shift Lever
I never liked the short stubby shift lever on our 5 speed trannies. After installing an MGW short throw unit I liked the short lever even less as over all effort is higher with the MGW. Although the short levers have been fashionable for years now I decided to try something longer.
After checking with all the usual Mustang vendors I came up dry so I tried EBay and to my surprise there were several outfits that sold shift lever extenders. A little careful searching and I found a 6" bent extender with the proper thread pitch. Honestly I was skeptical of whether it would work but for only $17 I was willing to try it.
The part was very nicely made, seemed strong and heavy and the threads were well cut. A few minutes later I headed out for a neighborhood test drive and was amazed at how smooth and light the shifter felt. Yes, the throws are longer but the feel is much nicer in my opinion. I'm not a drag racer so another tenth of a second or so on up shifts means nothing to me. The tall lever actually brings the shift **** closer to my hand position on the steering wheel.
I'll likely get a new shift boot from Redline with a smaller aperture as I won't need the boot retainer that the stock lever uses. I love it when a simple and inexpensive mod works so well.
Old Jan 20, 2017 | 09:30 PM
berzerk_1980's Avatar
This is a neat idea. Sounds like it would make daily driving more comfortable and you could always take it off if you were going to the drag strip or track.
Old Jan 20, 2017 | 09:45 PM
tbear853's Avatar
From: the beautiful "Shenandoah Valley of Virginia"
I like it.
Did a similar mod after adding my Hurst a couple years ago, and it's still got a 3-4 throw that's way shorter than the OEM's 4 inch throw. Up there the ball is near the hand on the wheel, is easier to stir over a tea or coffee in the cup holder, and it get's your right elbow well above that forward edge of the console lid. Pluses all around.
https://themustangsource.com/forums/...thread-523689/
Old Jan 21, 2017 | 12:06 PM
Jack Straw's Avatar
Hi tbear,
Thanks for the link to your earlier thread on shifters. Shortly after I installed my MGW unit along with a Q-ball **** I began to notice a bad rattle under load over 3000 rpm when the tranny was hot after a long hard canyon run. Obviously something changed the vibration frequency. I re-installed the stock shift **** and the noise was markedly reduced to a tolerable level. I have not had the chance to thoroughly exercise the car with this new long lever as the Arizona high country is currently covered in snow. I'll report back when I find out how the vibration/noise deal plays out.
BTW, on the subject of long shift levers, Ferrari used some pretty tall ones in the late fifties and early sixties. Here are a couple of pics of the legendary 250 GTO levers and gates, gorgeous work I'd say. Wouldn't a gated shifter look primo in a 'Stang?
Old Jan 22, 2017 | 06:34 AM
1 Alibi 2's Avatar
Have never been a fan of the " ball " shift ****, recently put this in my 14.
Bolted right up to the stock linkage base, also gained a little height.
Old Jan 24, 2017 | 09:09 PM
tbear853's Avatar
That looks really GREAT! Got me to looking at Hurst's pistol grips myself!
06-18-2018
Still have the ball, getting ready to install Hurst Line Lock kit on our '08 mostly to add an easy to use hill holder for "Wife Unit" to use … last couple years been a battle but Drs. say looking great after auto-stem cell transplant ..
