Longer Shift Lever
1 Attachment(s)
I never liked the short stubby shift lever on our 5 speed trannies. After installing an MGW short throw unit I liked the short lever even less as over all effort is higher with the MGW. Although the short levers have been fashionable for years now I decided to try something longer.
After checking with all the usual Mustang vendors I came up dry so I tried EBay and to my surprise there were several outfits that sold shift lever extenders. A little careful searching and I found a 6" bent extender with the proper thread pitch. Honestly I was skeptical of whether it would work but for only $17 I was willing to try it. The part was very nicely made, seemed strong and heavy and the threads were well cut. A few minutes later I headed out for a neighborhood test drive and was amazed at how smooth and light the shifter felt. Yes, the throws are longer but the feel is much nicer in my opinion. I'm not a drag racer so another tenth of a second or so on up shifts means nothing to me. The tall lever actually brings the shift knob closer to my hand position on the steering wheel. I'll likely get a new shift boot from Redline with a smaller aperture as I won't need the boot retainer that the stock lever uses. I love it when a simple and inexpensive mod works so well. Attachment 184432 http://i117.photobucket.com/albums/o...ps6zi4u8oa.jpg |
This is a neat idea. Sounds like it would make daily driving more comfortable and you could always take it off if you were going to the drag strip or track.
I like it.
Did a similar mod after adding my Hurst a couple years ago, and it's still got a 3-4 throw that's way shorter than the OEM's 4 inch throw. Up there the ball is near the hand on the wheel, is easier to stir over a tea or coffee in the cup holder, and it get's your right elbow well above that forward edge of the console lid. Pluses all around. https://themustangsource.com/forums/...thread-523689/ |
2 Attachment(s)
Hi tbear,
Thanks for the link to your earlier thread on shifters. Shortly after I installed my MGW unit along with a Q-ball knob I began to notice a bad rattle under load over 3000 rpm when the tranny was hot after a long hard canyon run. Obviously something changed the vibration frequency. I re-installed the stock shift knob and the noise was markedly reduced to a tolerable level. I have not had the chance to thoroughly exercise the car with this new long lever as the Arizona high country is currently covered in snow. I'll report back when I find out how the vibration/noise deal plays out. BTW, on the subject of long shift levers, Ferrari used some pretty tall ones in the late fifties and early sixties. Here are a couple of pics of the legendary 250 GTO levers and gates, gorgeous work I'd say. Wouldn't a gated shifter look primo in a 'Stang? Attachment 184430 Attachment 184431 |
Have never been a fan of the " ball " shift knob, recently put this in my 14.
Bolted right up to the stock linkage base, also gained a little height. . https://s25.postimg.org/igfrk0s33/Hu...3_2016_002.jpg . |
Originally Posted by 1 Alibi 2
(Post 7005863)
Bolted right up to the stock linkage base, also gained a little height. . https://s25.postimg.org/igfrk0s33/Hu...3_2016_002.jpg . 06-18-2018 Still have the ball, getting ready to install Hurst Line Lock kit on our '08 mostly to add an easy to use hill holder for "Wife Unit" to use … last couple years been a battle but Drs. say looking great after auto-stem cell transplant .. |
