long tube headers and running lean
if a motor runs its best the leaner the air to fuel ratio can be set without hurting or spark knocking then what would be the reason of having to change the tune if plugs look ok and its not spark knocking after putting long tubes with a cat pipe (kooks) on it?i know it should probably be dynoed and checked but till i can get it done i wouldnt think it would hurt to drive it til i can get it done.what do you think,retune first or drive it if everything seems ok?
