Line Locks
There has been some discussion in this thread here and I decided to start a new thread for it.
I'm looking to do it myself this year. Anybody else do it yourself?
I plan on buying two B&M solenoids and doing the wiring and plumbing from scratch. Blazing Saddles has mentioned that compression fittings are not track legal and you must used the double flared fittings. I know nothing about doing brake work myself. I am buying a service manual DVD to show me how to bleed the lines, etc.
I won't have any issues with the electrical wiring. I think I would just wire them in series and run the wire through the firewall to a switch.
I have no idea what hose fittings or other parts I need to buy. It would be cool if somebody picked up a Jegs or Summit catalog and made a parts list of all the stuff you need to do it yourself.
Guest
Posts: n/a
Originally posted by 05STG1@December 29, 2005, 7:55 AM
Im interested. I thought the hard part was tracking down the proper size fittings?
I cut the flares off the stock lines and removed the short flare nuts. I then peeled back an inch and a half of the black covering on the lines. I got a pair of longer flare nuts at Pep Boys and slid them onto the stock lines and double flared them. Now the stock lines will fit any standard fitting.
I then cut and bent the line that goes from the line lock to the rubber hose and installed the stock flare nuts on the end that goes to the rubber hose.
If you don't feel comfortable doing this then you should consider buying the kit from Pauls HP.
1. The new flare nut added to the stock line.
2. The stock flare nut added to the new line.
Thanks George, very much appreciated
I guess its not that bad. I think I could gather the courage to try this.Think Ill give it a try in a month.
Good tips, hope those interested are paying attention
Dustin, you going to try this ?
I guess its not that bad. I think I could gather the courage to try this.Think Ill give it a try in a month. Good tips, hope those interested are paying attention
Get a piece of brake tubing at your favorite parts store and with your handy double flaring set (probably available at the same parts store or any reputable tool dealer), do some practice flaring before you go after your car. It's not difficult, but there is a knack to getting the double flares correct. And as you well know, its not good to have brake fluid squirting out just when you've completed your first 12.7 pass!
This is not a no brainier with the double flare and George is definitely smarter than the above average bear. Personally I would go with Paul's Performance kit because all the parts are there. I feel he could at least supply the tubing pre bent as his price is $300. He did so on the Hot Rod magazine project. I would need a tubing bender with a small radii for sure. I wonder if Classictube.com could make up a line lock system? Might be worth looking into.
My 2 cents
My 2 cents
Do you like to..."Do-it-yourself"?
Sorry, I just had to throw that line out there...saw the movie again last night.
Good tip, practice never hurts
My 2 cents
My 2 cents
I know for a fact because the adjustable proportioning valve I put in my previous car was a true PITA.
The paul's HP kit doesn't come with pre-bent tubes, you still have to bend them yourself. So essentially the paul's HP kit doesn't do anything for you except charge you for overpriced components.
How much does a bending/flare tool cost? This looks pretty easy.
I just don't know how to properly disconnect the brake system and bleed the lines when you hook it back up. I hope the ford service manual i just bought on ebay will help me with that.
Thanks for the pics and advice george.
Originally posted by nonsensez9@December 29, 2005, 6:49 PM
another newb question: supposing the solenoids were placed up by the master cylinder, how does that muck with the ABS and/or traction control?
Guest
Posts: n/a
The tubing bender can be bought for 10 bucks. The double flareing tool for 20 bucks. You can Google "how to double flare" there are numerous sites that give instructions. If you use the Biondo solenoids you should be able to do it yourself for about 150 bucks.
Originally posted by dustindu4@December 30, 2005, 1:44 AM
this might sound like a stupid question, but is a double flare a tube that is flared on both ends? You put the fittings over the tubes, then flare both ends right?
You do of course have to put the fittings on the tube (put them on in the correct orientation also) before the flaring is done, and you will have to do both ends, but that's not what a double flare means.
A double flare refers to the process of making a flare that is basically folded over onto itself. The first step is a simple widening of the end of the tube. This is done with a cone shaped tool that is forced into the end of the tube. Then with tubing still held in the clamping fixture and with just the right amount exposed, the die in the flairing set is used to start a fold of the end of tube back towards the inside, then the flare is completed with the flare tool again used to final shape the flare. It ends up forming a double thickness of metal in the flared portion. You'll know you have it right when there is a uniform amount of tube that is folded over and the flare is concentric with the tube and uniformly shaped.
This is much harder to describe in words than actually showing or doing it. It's not a no brainer, but if I can do it, I know you can too.
Hope this helps.
Originally posted by slammer223@December 30, 2005, 9:28 AM
They used to tell us that the only stupid question is the one that isn't asked....
A double flare refers to a flare that is basically folded over onto itself. The first step is a simple widening of the end of the tube, then with the die in the flairing set, the end of tube is folded back towards the inside, forming a double thickness of metal in the flared portion. This is much harder to describe in words than actually showing or doing it.
In the graphic below, the top pic is a double flare:
