Are LCA relocation brackets necessary if the car is lowered?
Old Jan 18, 2007 | 10:53 PM
Jon_Purdy's Avatar
That may be a silly question to some but I need to know. I ask because I am looking at getting the Roush Complete Suspension Kit along with the lower trailing arms. However, if you look at their website, there is no mention of them anywhere.
Jon
Old Jan 19, 2007 | 05:59 AM
Galaxie's Avatar
I Have Admin Envy
I don't know how critical it is on the street, but for the best possible traction at the strip, its best to get the instant center at its ideal location, espeically when the car is lowered
Just an FYI, i'm currently working on a detailed writeup about lowering your car and the negatives that may need to be corrected.
Old Jan 19, 2007 | 09:11 AM
mot250's Avatar
I'll be looking forward to that write-up. I'd like to drop mine 1 inch or so but I want to make sure I figure in all of the "corrective" parts necessary to make sure it is done right since I want this car to be safe and capable on the track and not just "look good" lowered.
Old Jan 19, 2007 | 09:27 AM
traffic142's Avatar
I got BMR lowering brackets. Here is why. When you lower the car, you lessen the angle the LCA and the axel have in relationship with the car frame. All this means is you have more wheel hop. BUT since you already have wheel hop on the stock car, probably no biggie.
I put the LCA lowering brackets from BMR and I do not have any wheel hop now. No I did not weld them in, just bolted them on. They suggest welding them if you get really good 60 foot times.
For a while, BMR was the only ones who offered them, now I noticed that Steeda is also offering the welding kind. I feel that Roush will follow suit soon.
Side note, you may need to adjust your panhard bar if you start to run wider tires on the back end to avoid rub.
Old Jan 19, 2007 | 09:36 AM
sook's Avatar
While you may not need the relocation bracket, you should also look into an adjustable upper control arm to correct pinon angle and like traffic142 said, an adjustable panhard bar to correct back wheel offset. Maybe some camber bolts to correct front end alignment. You may not need any of these things, but just an extra expense that may come up after your roush kit is installed.
Old Jan 19, 2007 | 10:05 AM
traffic142's Avatar
I agree with the caster/camber bolts..... You may need them if you drop your car a good deal. Most of us have found on this forum, that if you stick with drops of less than 1" to 1.5" you will be fine (ie. steeda ultra lite springs). I have heard of extreme drops of 2" will cause you problems of alignment and later if you install headers that hang below the frame...You will drag.
Old Jan 19, 2007 | 10:11 AM
sook's Avatar
Agreed, most experienced alignment shops can get the car back into spec without camber bolts or plates. But if Jon_Purdy is spending that much $$$ on handling mods, hey may be planning on autocrossing and may need more adjustability with the alignment.
Old Jan 19, 2007 | 03:28 PM
RadBOSS's Avatar
A job that is worth doing is a job that is worth doing right. Its worth the effort to do the LCA pivot drop and the other mod's described above if you want your Mustang to be all that it can be. Also not mentioned is the front ball joint drop (steeda) to get the front roll center back up.
Old Mar 8, 2011 | 08:19 PM
Hamhole's Avatar
I came across this recently and it did a pretty good job of explaining how the LCA acts as a brace for forward forces and what happens when a lowered car changes it from being stock-level to raised up in the rear. Forces end up lifting the axle and giving you wheel hop.
http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
Old Mar 8, 2011 | 08:35 PM
Dixie_Flatline's Avatar
I think you win an award for oldest post resurrected.
That being said, that whole writeup on suspension has been a huge help to me over the past few years in understanding how our rear suspensions work.
That diagram simplifies matters greatly, and increased traction going straight isn't nearly the same as increased traction around corners with regards to the angle of LCAs.
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Ecostang
Nov 3, 2022 08:50 PM
SMBJoshy
Aug 24, 2015 10:55 AM
Big-D
Jul 27, 2015 11:24 AM
killaz05
Jul 24, 2015 08:49 AM
