Lakewood watts link...
That is a good price and is even cheaper than the Fay's watts linkage. I still like the Saleen watts linkage looks the best and has the most factory appearance. I hope that the low prices of the other two watts linkages makes the price on the Saleen version go down.
Don't count on it. When you look at the prices of Saleen & Roush parts compared to others their always alot more expensive. Understanding that Saleen's kit does differ from the other two I still wouldn't expect much of a price drop if any.
It will have to drop if it does essentially the same thing. The Saleen kit is more than twice the amount of the other two kits. If the Lakewood and The Fays does the job just as well or even close no one will buy the Saleen kit. It is a matter of suply and demand.
![Stickpoke](https://themustangsource.com/forums/images/smilies/stickpoke.gif)
The Saleen kit's only real advantage is weight savings (which is an important factor for guys that actually run road coarses. I agree that the Lakewood "U" bolts are cheap and put more stess on the axle housing than they should. But, I'm not really keen on the differential cover solution that Saleen uses. I think the Fays2 is the best of the three choices foor a car that is driven on the street.
One additional thing to consider on the Saleen pricing is that the kit includes the rear roll stabilizing bar in the kit. Not that it warrants a $600 markup...but it does justify another $200.
![Icon Rolleyes](https://themustangsource.com/forums/images/smilies/icon_rolleyes.gif)
hi all,
my performance/auto technician buddy read over the lakewood write up, looked at the fays and saleen and he is not convinced of the usefulness.
he says it seems to him its a fancy panhard bar. i guess what he is saying if its truly worth the COST associated with it....
i guess for the serious road course driver yes, but for regular guys..not sure....
what does everyone else think?
The Fays is only about $300 more than a Steeda panhard and brace. Is it worth it? Well most of the parts for our cars will never see any where near their limit on the street. Will a guy with 600 HP ever get that car to hook up on street tires. No, but he still has bragging rights (until a car with 400 does hook and blows by him!!!
![Rollinglaugh](https://themustangsource.com/forums/images/smilies/rollinglaugh.gif)
Well, first, it is NOT a panhard bar in any way shape or form. It completely replaces the need for a panhard bar. You should read through the FAQs on Fays website for more info.
) So I guess the question is do you think it's worth it? ![Stickpoke](https://themustangsource.com/forums/images/smilies/stickpoke.gif)
it sure does look cool though!
for street guys it's really a waste of money. the uneven surfaces and lack of grip on the streets negate the benefits in the first place.
Both the Lakewood and Fays are attached to the axle tubes - not so good.
I'm waiting for RossMustang.com to release theirs. Or guys can go with Griggs. The guys that will truly benefit from a Watt's link arent buying the lakewood or Fays units.
I disagree. People who use it on the street will get some benefit from a watts linkage system. Maybe not as much as they would on the track but their will be a benift. A watts link is great for eliminating torque steer especially on uneven surfaces. There are also many places where there are curvy roads that are nice and smooth and would be fun for street drivers.
A Watts linkage is superior to a panhard bar. A panhard bar connects to the car on one side and the axle on the other and operates on an arc. (great if turning in only one direction, like on a circle trick) The rear axle is almost never at dead center.
Watts linkage operates vertically making it the perfect solution for a car turning both left and right.
If you compare the Fays2 and the Lakewood, I think you will see the construction of the Fays2 is beefier and stronger.
Try Summit Racing it cheaper $387.00
http://store.summitracing.com/egnsea...00+115&x=9&y=7
Looks nice enough. Not really keen on the axle clamp up solution. I like the Saleen PJ set up much better though.
MRGTX
8/21/15 08:49 PM
