Kenne Bell Installed ( Limp Mode)
Old Jun 22, 2006 | 09:30 AM
Slofoot's Avatar
The problem is in the tune. Is it the KB supplied tune? If so I'd be on the phone now. Sounds like you have a bum tune. Good luck.
Old Jun 22, 2006 | 03:38 PM
70MACH1OWNER's Avatar
I agree
I have to agree that it is a tune issue. Not many MECHANICAL ISSUES will throw a CEL as fast as you discribe. I would be on KB like stink on pooh!
Scott
Old Jun 22, 2006 | 08:45 PM
94tbird's Avatar
i got the limp home mode once after an extended period of cruise control at 70mph or so. i turned car off and back on and it went away. Kenne Bell admitted that it is in the tune and told me to send tuner back. i havent yet because i am getting custom tuned By Larrocca Performance in less than a month.
Old Jun 24, 2006 | 11:01 PM
FoMoCo's Avatar
P0443 - Evaporative Emission (EVAP) Control System Canister Purge Valve Circuit Malfunction
Description: The powertrain control module (PCM) monitors the state of the EVAP canister purge valve circuit output driver. The test fails when the signal moves outside the minimum or maximum limit for the commanded state. Possible Causes:
  • VPWR circuit open
  • EVAP canister purge valve circuit shorted to GND
  • Damaged EVAP canister purge valve
  • EVAP canister purge valve circuit open
  • EVAP canister purge valve circuit shorted to VPWR
  • Damaged PCM
Diagnostic Aids: To verify normal function, monitor the EVAP canister purge valve signal PID EVAPPDC (or EVMV for electronic valve) and the signal voltage (PCM control side). With the valve closed, the EVAPPDC indicates a 0% duty cycle (0 mA for EVMV) and voltage approximately equal to battery voltage. When the valve is commanded fully open, EVAPPDC indicates 100% duty cycle (1000 mA for EVMV) and a voltage drop of 3 volts minimum is normal. Output test mode may be used to switch output on/off to verify function. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to HX1 .
CiniZter
25
Apr 28, 2016 05:41 PM
Fastnloud
Feb 15, 2016 05:21 PM
Allen Hanback
Sep 14, 2015 04:37 PM
