KB Boost-A-Spark
Old Jan 21, 2010 | 11:44 AM
05bluestang's Avatar
KB Boost-A-Spark
I'm about to install the KB BAS module this weekend. I got it all figured out except for the part where you tie it into the coil circuit. How do you get the under hood power center out to get to the bottom
connectors? Anybody install one of them? Any help would be great so I don't butcher this up.....
Old Jan 21, 2010 | 07:10 PM
Redrocket06's Avatar
This link helped me out with my install, great pictures too. Let me know how it goes.....
http://mustangforums.com/forum/2005-...ll-w-pics.html
Old Jan 21, 2010 | 09:49 PM
Thanks but thats the boost a pump install, I am installing the boost a spark module....
Thanks anyway
Old Jan 22, 2010 | 04:30 PM
NastyStang113's Avatar
Just curious but why are you installing it?
Old Jan 24, 2010 | 09:50 AM
classix_stang289's Avatar
when is something like a boost-a-spark module required?
Old Jan 24, 2010 | 10:40 AM
70MACH1OWNER's Avatar
Not sure where that line in the sand is at but I have seen a number of S197 Stangs running 475-500 rwhp on the stock ignitions with no issues. Not that it is a bad idea. I ran one on my KB boosted 96 Cobra. But this coil on plug system is way better.
Old Jan 24, 2010 | 05:43 PM
thats good to hear.
Old Jan 25, 2010 | 07:58 AM
Chris Rose claims I am not making enough HP due to spark voltage being too low. Instead of replacing the whole engine wiring harness (which I will do down the road) because of an intremittened short which causes a voltage drop, I decided to give the BAS a try (It's only $225.0) and see if anything changes with the increased spark voltage. I mounted it over the weeken but did not have the ba**s to splice it in, that's where Tillman is comming in.............
Old Jan 26, 2010 | 08:28 PM
TillmanSpeed's Avatar
Former Vendor
We'll see how the B-A-S does... I really don't even know if it's going to solve the problem or not.
I think it's an intermittent wiring issue, honestly...
Your spark PID shows exactly what we're asking for, the air/fuel ratio is dead on, the rest of the datalog is perfect... there's really only one thing it could be... ignition. We tried different coils and plugs with no luck, it has to be in a connector or a ground or something not adding up in the harness.
I don't think the B-A-P will fix the problem, but I'm curious to see if it "tricks" it.
Chris
Old Feb 9, 2010 | 05:00 PM
kentompkins's Avatar
How did this turn out? And how did you hook this thing up?
Evolution Performance
Jul 5, 2008 09:30 PM
