Just installed my JLT Xcal2 from Bamachips
It is a hugh difference!! Welcome to the club. I was swapping between the Bamachips 91 Race and 91 Torque tunes this weekend....there is a difference and I like them both - but the rush of the 91 torque Tune when you hit a 3k punch is awesome....the beast just flat LEAPS ahead
I was doing the same thing. I went with Bama because I have an auto and I heard only great things about Doug's tune so I went with him. It was an easy install also. Trust me I am a novice at this stuff.
I've had my JLT II since my '05 GT and Jay Tucker is great to deal with. He stands behind his product and it just flat works. I originally chose the JLT with XCal I/DLP tune combo for the '05 as it was showing one of the best hp gains and was reasonably priced. I finally upgraded to the XCal II when I bought the '07 since the programming was different and I needed to get another tune anyways. Doug's tunes are great and the JLT/BAmaChips combo just works well.
Onirb..... does that heat shiel you have on your JLTII come with it from Bamachips??? That is one of the reasons I was looking ot get one from Tillman, because they sell thier Heatshields. Every picture I see....shows it without the shield.....and it makes it look so much cleaner...not to mention helps with Cold Air seperation from the Engine.
Did it get rid of the lag when you step on the throttle? Can you really feel the difference, or is it mental?
The heat sheild came with the setup. It is the same shape but plastic if I remember correctly (long day at work). I was thinking of buying the tillman sheild but I am going to wait untill I hear some reviews.
To me some lag is their but not as much as before. It is definately quicker.
Your car with the tune: Did the response change to where you can peel off...
Glad to hear your happy.
Thanks for your post and order. Doug is a great tuner and can make a Mustang scream.
BTW, You have the elbow on the throttle body backwards. The short side goes on the throttle body. The part #'s should be on the bottom.
Also, All JLT kis come with the plastic heat shield you see here. Plastic is much better at keeping heat from the filter. We use 1/4" think plastic for this very reason.
Jay
Jay
Doh! I said I was new at this. Off I go.
Back already. Now that is the reason why to go with this combo. Great customer service!
Jay
Jay
Yes it did and the 91 Race Tune from BamaChips makes that throttle very eager and yes it is a BIG difference, not only do you gain RWHP but the largest difference (IMO) is the improvement in overall drivability - I have a stick - but for those with autos - it is even a larger improvement I'd imagine
