JLT & Shaker Hood Combo 2005-2009 Mustang*
Old Jan 17, 2007 | 10:00 PM
praztek's Avatar
Has anyone done this , read somewhere that the Shaker tube doesnt reach the JLT heatshield?
Old Jan 17, 2007 | 11:20 PM
RedDragon777's Avatar
if you go with a Fang Performance shaker the hood has the ducting in it and it will push air right ontop of the JLT plus it is a new hood so you will not have to worry about cutting into your factory
Old Jan 17, 2007 | 11:58 PM
LEO_06GT's Avatar
Yeah but that's also more than double the price of buying the CDC shaker. The fang shaker and hood cost $1275 plus tax and S&H. Then add atleast another $600 for prep/paint and install at your local body shop. I bought the CDC Shaker and had it installed for $1100. The majority have just bought the shaker and done it themselves. If you have the cash then by all means get the fang shaker.
Old Jan 18, 2007 | 06:45 AM
tom281's Avatar
Here you go....
Old Jan 18, 2007 | 12:14 PM
praztek's Avatar
Awesome..............Thanks!
Old Jan 18, 2007 | 12:21 PM
TillmanSpeed's Avatar
Former Vendor
JLT is A++++++++++++++
Old Jan 18, 2007 | 02:16 PM
tom281's Avatar
Let me know if you need further info or details.
Old Jan 18, 2007 | 03:10 PM
praztek's Avatar
Was there any chance of bringing the Shaker tube into the JLT Heat shield at a straight angle, or was it easier to just route it at the bottom, similar to the stock air box setup. Example of a C&L setup shows the inlet coming in from the top location of the heat shield.
Attached Thumbnails JLT & Shaker Hood Combo 2005-2009 Mustang*-a0d1b5ea4c17454797468c162f137c11copyzb4.jpg
Old Jan 18, 2007 | 03:49 PM
tom281's Avatar
In my situation it was easier to route it in at the bottom. Also I'm not sure if the JLT heatshield sits as high as the C&L.
Old Jan 18, 2007 | 03:53 PM
metroplex's Avatar
Props to you... I could never cut a hole in a perfectly good and new hood!
Old Jan 18, 2007 | 03:55 PM
70MACH1OWNER's Avatar
It is the same on the C&L intake. I have the CDC Shaker with the C&L intake and my hook up looks just like TOM281's. I had pics but it looks like I deleted them. I had to cut 1 1/2 inches out of the vertical portion of the CDC air tube and glue it back together to make it come in at the bottom of the heat shield. I can take more pics if anyone wants.
Scott
Old Jan 18, 2007 | 03:57 PM
I don't want to speak for Tom but just get a 6 pack of your favorite brew, get the drill and the jigsaw and go for it.
Scott
Old Jan 18, 2007 | 05:04 PM
praztek's Avatar
Sure, send pic's when you have a moment. Just planning out what I'm going to do prior to the JLT arriving in the mail.
It is the same on the C&L intake. I have the CDC Shaker with the C&L intake and my hook looks just like TOM281's. I had pics but it looks like I deleted them. I had to cut 1 1/2 inches out of the vertical portion of the CDC air tube and glue it back together to make it come in at the bottom of the heat shield. I can take more pics if anyone wants.
Scott
Old Jan 18, 2007 | 06:21 PM
tom281's Avatar
Scott
Ah yes, proper refreshments are the key for any garage work. You and I are on the same page Scott- drinking out of the same glass if you know what I mean.
Old Jan 19, 2007 | 03:57 AM
I'll re-take a few tonight after I get home of work and post them.
Scott
Old Jan 19, 2007 | 07:24 AM
praztek's Avatar
Does the filter sit higher than the heatshield and if so how much of hit ends up hitting the hood cover if any?
Old Jan 19, 2007 | 07:29 AM
OKCMustangGT's Avatar
Definitely do it yourself. You will appreciate it so much more. The actual cutting the hole is not that intimidating, because once you cut out the template with a razor knife and score the paint on the hood, you are at the point of no return. Then you just relax, get a firm grip on the jigsaw, use the appropriate blade and walk it around the hole. Of course be prepared for your neighbors to think you have lost your mind, cutting a hole in your new Stang's hood
I got some pics and a brief write-up on when I did my CDC Shaker Install if you need them.
BTW, when the weather clears up I will be installing the C&L CAI and doing something similar to the setup shown a few posts back.
Attachment 17729Attachment 17730
Attached Thumbnails JLT & Shaker Hood Combo 2005-2009 Mustang*-shaker-done-close-up-1-web.jpg   JLT & Shaker Hood Combo 2005-2009 Mustang*-shakerinset.jpg
Old Jan 19, 2007 | 02:18 PM
You must be a more proper man than I. I won't let it waste any time in a glass. Straight from the can to the lips for me!!
Old Jan 19, 2007 | 03:09 PM
I know this thread is about the JLT and CDC Shaker but for those that have a C&L it is equally doable. Attached is a few pics of my setup. Mine is very similar to TOM281's. I cut 1 1/2 inches from the vertical part of the air tube and glued it back together to get it to come up to the bottom of the C&L heat shield. I than turned up an aluminum spacer to go between the airtube and the heat shield. A little black paint and tadaaaa! It works great. Looks from these pictures I need to get my filter cleaned soon. Jeez!!!
Scott
Attached Thumbnails JLT & Shaker Hood Combo 2005-2009 Mustang*-shaker-c-l-1.jpg   JLT & Shaker Hood Combo 2005-2009 Mustang*-shaker-c-l-2.jpg   JLT & Shaker Hood Combo 2005-2009 Mustang*-shaker-c-l-3.jpg
Old Jan 19, 2007 | 03:22 PM
tom281's Avatar
Looks nice Scott! Cool!
