JLT CAI
Changed out my TB yesterday and found this.
You may want to check your vacuum line from your intake.
Mine had a small hole in it. Never even threw a code.
The line must have been a bit to long and at high speeds it touched the upper pulley which made the hole. Just a heads up guys.
I think I will see if I can get a better vacuum line to replace it.
Steve
Steve
I can go one better. My vacuum hose was cut clean it two by the pulley. No code, but the loud whistling was a dead give away.
I replaced it with more rigid 3/8" fuel line. Problem solved.
Originally posted by Mongoose@September 17, 2005, 11:48 AM
Are you talking about the line from the JLT and the rocker cover?
Steve
Originally posted by Cleveland@September 17, 2005, 11:51 PM
It may be a bit overboard but I replaced mine with actuall steel braided 3/8" hose and fitting ends that I "had laying around"
-Dan
-Dan
Got pics?
I noticed mine hung low when installed. So I looped it over a wire (one which I can't remember off the top of my head). So it sits higher off of everything.
I found a hole in mine also after my mechanic re & re'd the JLT to do my headers and wasn't quite so careful about where that hose hung. It's still got electrical tape wrapped around it until I get around to replacing it...
