JLT CAI
Old Sep 17, 2005 | 07:23 AM
SC67Stang's Avatar
Changed out my TB yesterday and found this.
You may want to check your vacuum line from your intake.
Mine had a small hole in it. Never even threw a code.
The line must have been a bit to long and at high speeds it touched the upper pulley which made the hole. Just a heads up guys.
I think I will see if I can get a better vacuum line to replace it.
Steve
Old Sep 17, 2005 | 08:22 AM
Clem's Avatar
I can go one better. My vacuum hose was cut clean it two by the pulley. No code, but the loud whistling was a dead give away.
I replaced it with more rigid 3/8" fuel line. Problem solved.
Old Sep 17, 2005 | 10:45 AM
Mongoose's Avatar
Are you talking about the line from the JLT and the rocker cover?
Old Sep 17, 2005 | 04:21 PM
Hatchman's Avatar
Yes, the hose that goes from the bottom of the JLT tube to the top of the passenger side cam cover. I saw the potential for pulley abrasion, and have mine ziptied to a bracket right under the throttle body. Can't see the ziptie, and the hose can't dangle on the pulley and get chopped.
Old Sep 17, 2005 | 08:16 PM
SC67Stang's Avatar
I did the same thing. Worked like a charm.
Steve
Old Sep 17, 2005 | 09:25 PM
Mongoose's Avatar
I will check mine when son returns GT Thanks
Old Sep 17, 2005 | 10:48 PM
Cleveland's Avatar
It may be a bit overboard but I replaced mine with actuall steel braided 3/8" hose and fitting ends that I "had laying around"
-Dan
Old Sep 18, 2005 | 07:29 AM
Hatchman's Avatar
-Dan
I imagine that would look much better.
Got pics?
Old Sep 19, 2005 | 10:33 AM
Kluski's Avatar
I noticed mine hung low when installed. So I looped it over a wire (one which I can't remember off the top of my head). So it sits higher off of everything.
Old Sep 19, 2005 | 12:26 PM
Redfire 05Gt's Avatar
I found a hole in mine also after my mechanic re & re'd the JLT to do my headers and wasn't quite so careful about where that hose hung. It's still got electrical tape wrapped around it until I get around to replacing it...
14Glassback
Oct 4, 2015 08:52 AM
MustangConvert11
Sep 30, 2015 08:01 PM
RoushRS3
Sep 29, 2015 08:03 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
SterlingStunner
Sep 16, 2015 12:30 PM
