JBA Longtubes and H-pipe
Old Feb 4, 2005 | 03:25 PM
zwooky's Avatar
Will I need a new tune after installing the JBA longtube headers and h-pipe? Also will the check engine light come on? Thanks for any info.
Old Feb 4, 2005 | 08:23 PM
Vegasjay's Avatar
The light will come on. Mainly because the old H-Pipe didn't come with sensor bung's welded in them. I didn't run the cat sensor's because of this. The new H-Pipe's thier sending out should have them and you'll be O.K. JBA is sending me some bung's to weld in, should take car of the light. A tune should help get more power and you will be able to adjust the air/fuel ratio. Is a tune absolutly nessasary? I would say less so, than changing the air intake IMO. You will LOVE the sound that's for sure, as long as you like it extremley LOUD!
Old Feb 5, 2005 | 09:10 AM
dhof303's Avatar
Justin, when you installed the headers yourself did you have access to a lift or did you do it in your driveway with jackstands and a engine hoist or a jack? This task is upon me this week.
Old Feb 5, 2005 | 11:35 AM
Vegasjay's Avatar
Originally posted by dhof303+February 5, 2005, 10:13 AM--><div class='quotetop'>QUOTE(dhof303 @ February 5, 2005, 10:13 AM)</div><div class='quotemain'><!--QuoteBegin-Vegasjay@February 4, 2005, 9:26 PM
[/b][/quote]
Derek, Ya unfortunately I had to do it in my garage and with a jack and stands. That is what added alot of time to the install. It's not that it is impossible with out one, it's just all the sliding under and back out about a 1000 time's that rack's up time and pain!! I used a very small bottle jack and a wooden wedge (under the bottle jack) to lift the motor. There's a relatively flat spot on the cross-member directly under the motor mount where I placed the bottle jack (I used the wooden wedge to shim the jack up), and I lifted against the motor mount. But that won't work If your changing the motor mount's too. :notnice: When my motor mount's arrive, I was planing on using an engine hoist, you may need to do the same. There's not many good spot's under the motor to jack from. I sure wished I would have done my motor mount's at the same time....I thought about it, but JBA wasn't recomending it at that time. :bang:
Another thing I had to do, was remove all the stud's on the passenger side. JBA say's in thier instructions to leave the top forward stud in, then place your gasket on, then the header. I couldn't make up the header with that stud in place, so I removed it. Just a head's up if you have a hard time, remove the last stud and it'll go on! If you have any more question's I'll try to answer them the best I can. Good luck.
Old Feb 5, 2005 | 03:59 PM
dhof303's Avatar
Justin, thanks for the heads up. Should I get my car back from the paint shop and get my h-pipe in next week I will be wrenching away too. I have however received my motor mounts.
Sep 24, 2015 08:15 PM
haitham
Sep 8, 2015 12:52 PM
drmag
Sep 1, 2015 03:47 PM
Vader99
Jul 19, 2015 08:19 PM
2k5pony
16
Feb 2, 2005 01:08 PM
