Intercooler Temp gauge???
Old Sep 13, 2007 | 06:41 AM
dly's Avatar
dly
I'm thinking of using a standard mechiacal Water Temp gauge and plumb it into my SC intercooler line. Would this be smart or something I totally don't need to do. I'm thinking a tee with the temp probe screwed into it anf cut the line somewhere and clamp it back together.
Good thinking or bad????
Old Sep 14, 2007 | 06:30 PM
06GT4RAD's Avatar
Why would you need this?
Richard
Old Sep 14, 2007 | 09:52 PM
dly's Avatar
dly
To check the temp of the Intercooler fluid. That's why I'm asking. Is it something I need to monitor or doesn't the fluid get that hot. So far the Intercooler tank was not been very warn to the touch after driving around, so perhaps I don't need it but just asking questions.
Old Sep 15, 2007 | 05:13 AM
tom281's Avatar
Hum, I know I don't need one because my 'cooler is air-to-air...... the Saleen cooler must need water because it's not as efficient as the Paxton.
Just kidding Darrell- it sounds like a good idea to me.
Old Sep 15, 2007 | 08:09 AM
06GT4RAD's Avatar
My point is this. Why monitor it if you have no way to control it. In other words if you cannot lower the Temp then why concern yourself about what the temp is. Now if you have a way to control the temp and adjust it as you drive then i could see a need, otherwise I think your better off with a Engine Water Temp gauge.
Richard
Old Sep 15, 2007 | 08:50 AM
tmcolegr's Avatar
I think you would be better off monitoring post S/C air inlet temps (just as the PCM does) rather than intercooler coolant temps. If your air inlet temps are not excessive, there's no reason to monitor the coolant temps. After all, it is the air inlet temps that are critical and what controls when timing begins to be pulled and affects performance.
Now that being said, why don't you look into the MSD Dash Hawk.
K.A.I.N
Sep 25, 2015 03:27 PM
