Intake air temp
Old Oct 29, 2005 | 12:16 AM
Mongoose's Avatar
Where on the GT 4.6 motor is the inlet air temp sensor located? Is it part of the map or somewhere else? Outside temp was around 61 but measured the inlet air was 110 and I was doing 70 at the time. I use the JTL pipe
Old Oct 29, 2005 | 01:09 AM
Cleveland's Avatar
Was your car sitting still @ that reading's time? I have noticed that once you get moving and cold air enters through the grill the intake temp drops quickly. I datalog constantly now so I know what Im posting about.
-Dan
Old Oct 29, 2005 | 10:13 AM
The Lyin' King's Avatar
It's part of the MAF.
Old Oct 29, 2005 | 10:34 AM
05STG1's Avatar
Six wires on the MAF. Two for the ACT, four for the MAF, its all incorporated now.
Unless your sucking fresh cold air, u still need to account for the underhood temps these cars make.
Even at 70mph, and 60 degrees, your creating alot of heat under the hood, the engine has no choice but to suck up all that hot air.
Ive always said, heat extractors would benefit highly on these cars. To relieve the under hood heat, and pressure.
Just my $.02 worth
Old Oct 29, 2005 | 02:17 PM
Mongoose's Avatar
Thanks to all. I still don't see how I could be going 70 and the IAT at 110 when outside temp is in the 60s Maybe I need some louvers in the hood.
Old Oct 29, 2005 | 02:36 PM
MJC302's Avatar
[quote=Mongoose,October 29, 2005, 4:20 PM]
I've totally insulated my inlet air box and inlet to the TB. Before I insulated the inlet to the TB I measured up to 158F on the underside of the TB at idle. The inlet air box (or air filter housing) air temp hit 123F at idle. I also measured the underside surface of the intake manifold....165F. Air space temp between the engine top and the bottom of the intake manifold was 183F!! I hope to insulate the intake manifold this winter when I get my exhaust manifolds jet-hot coated. There are a few more threads on the heat subject tucked in the WMS discussion. Good luck.
May 3, 2026 05:42 AM
RoushRS3
Sep 29, 2015 08:03 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
